Help choosing external amp for my system
dbaldus
dbaldus Posts: 730
edited January 2008 in Electronics
Lately, I've been getting this crazy idea that I should upgrade my system by purchasing an external power amp. Here is my (current) system:
AVR: HK 247 (50 w/channel)
Fronts: Rti70s (recommended at 20-250 w/channel)
Center: Csi40 (recommended at 10-250 w/channel)
Surrounds: R15 (recommended at 20-100 w/channel)
I was originally considering just purchasing a 2-channel amp, but the more I read, the more I think it would be best to give extra power to my center channel also because I do a lot of HT/playing videogames encoded in DD/DTS. So now I am trying to decide between a 3-channel amp or a 5/7-channel amp.
I'm trying to stay around $500-$600, preferably closer to $500, so the 5/7-channel amp that comes immediately to mind is the Emotiva LPA-1, but unfortunately that is only 125 w/channel. This brings me to my first question...
1. If I do buy a power amp, should I buy one that can give me something closer to 250 w/channel (the recommended max power for both Rti70s and Csi40), or will I notice a difference with just the 125 w/channel? I'm just afraid that I won't be impressed if I only step up "halfway", but at the same time I'm not willing to spend more than $600.
2. Also, does anyone have any recommendations for a 3-channel amp that would possibly have more w/channel than 125 (or would just generally be better than the LPA-1) or another 5/7-channel amp that would be better than the LPA-1 altogether but still fall near my price range?
I'm looking for all sorts of suggestions, opinions, offers from people on amps they are trying to sell, deals people have found on amps that might suit me, etc. I want to TRY to get this right the first time and not end up upgrading again in a few years <fingers crossed...> ;)
Thanks in advance!
2-channel
Squeezebox Touch| MSB Analog DAC | Audio Research Ref 40 Anniversary Edition| Pass Labs X350.8 | Wilson Audio Sasha 2
Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2
  • cfrizz
    cfrizz Posts: 13,415
    edited December 2007
    Welcome. Since you really want to do it right the first time, you should up your budget. The more power you give your speakers the better they will sound. And it is not just a matter of loudness. You will have much more clarity, better separation of instrument, better bass, better vocals.
    I always recommend at least 200wpc of amplification. I also suggest going for the gold & getting a 5 channel amp & be done with it. You will keep that amp through all other upgrades to your system over the years.
    You can get a lot more amp for your money if you buy it used from Audiogon.
    Good brands we recommend, Outlaw Audio, Sunfire, Parasound, Rotel, Nad, & Adcom. Some have started recommending Emotiva as well.
  • Early B.
    Early B. Posts: 7,900
    I also typically recommend 150 - 200 wpc to newbies for HT (there are many other factors to consider besides watts). However, I have the LPA-1, and I see no need for more power. For the price, it's a no-brainer. Just buy it.
    "God grooves with tubes."
  • Lowell_M
    Lowell_M Posts: 1,660
    I have an ADCOM GFA-555 which is 200wpc that used to be powering my RTI70's and now have an ADCOM GFA-7000 which is 130 wpc powering all 5 channels. I would definately recommend a 5 channel amp. It filled in the surround sound so it is seamless and dialog is easier to understand.
    Also, the RTi70's aren't that difficult to drive. Both ADCOM's have produced fantastic, clean sound from the 70's without a sweat. I'm partial to ADCOM due to bang for the buck and I really enjoy their sound. See what you can find on Audiogon in a 5 channel ADCOM. I got my GFA-7000 around $500.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • dbaldus
    dbaldus Posts: 730
    a_mattison wrote: »
    Hmmm... the GFA-7000 sounds about right, especially if I can get it for that price. It sounds very similar to the Emotiva LPA-1 as far as wattage is concerned (it is 125 wpc). Do you have any experience with the Emotiva or which do you think would be higher quality between the two? Just wondering because I wouldn't have to look around for a used Emotiva since I can get it for under $500 directly from Emotiva.
    Also, can you tell a difference between when you had the 200 wpc going to your Rti70's compared to now only having 130 wpc? What was the difference and when did you notice it (ie listening to music, watching movies, etc.)?
    2-channel
  • glemay
    glemay Posts: 574
    I'm curious as to what a-mattison has to say about this seeing as I'm thinking of doing the same thing.
    Gerry
    Main System:
    Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
    Second System:
    Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
  • dbaldus
    dbaldus Posts: 730
    Early B. wrote: »
    Have you experimented with any higher wpc amps? Did you notice any major differences? What were they? I'm just trying to figure out why you said that you have no need for more power to see if I would potentially feel that way, too.
    Also, I already have a HK 247 receiver, so would it be strange to pair it up with an LPA-1 or would it be better to get the LPA-1/LMC-1 combo?
    2-channel
  • McLoki
    McLoki Posts: 5,231
  • dbaldus
    dbaldus Posts: 730
    McLoki wrote: »
    Thanks for the recommendation! Is that a well-known/respected amp and brand? Is it a "good" price? Do you have any idea what model that is just by looking at it? I'd like to do a little research on it - I'll contact the seller in the meantime...
    Thanks again!
    2-channel
  • McLoki
    McLoki Posts: 5,231
    acurus is a good brand name. It should be an A200 x 3. (3 channel amp)
    Here are some user reviews.
    AVS thread on it.
    It was the amp I was planning to get when I stumbled across my Cinepro. $500-$600 seems to be the going rate. I would say $500 shipped would be a good deal and worth getting.
  • chrisfinnerty
    chrisfinnerty Posts: 13
    Early B... I have 4 LSI9's and an LSIc, going to add a sub once I pick it out. Will the LPA-1 be enough power for me for HT or should I consider the IPS-1 for $400 more? Have you had any complaints with the fan noise when music is quiet?
    Thanks!
  • acsubie
    acsubie Posts: 773
    the LPA is a great amp for the price quiet as well and never even gets a bit hot with my RTi10s,CSi5 and RTi4, works great coupled with my onkyo 805....gonna prolly pick up their 200w 5 channel version once its released, even though im running a 7.1 system i just connect the rear back surrounds to the onkyo
  • dbaldus
    dbaldus Posts: 730
    So one of the guys that is selling his Acurus says this:
    "The main reason is because I have a ground loop somewhere in my room and don't have the time or energy to fix it"
    What does that mean? Is it a defect on the amp or his room itself? What would this sound like? Is it really noticeable/annoying? How would you fix it?
    And finally... will a ground loop effect all amps or just this one?
    2-channel
  • dbaldus
    dbaldus Posts: 730
    acsubie wrote: »
    Have you ever had experience with a higher wpc amp on your system? I'm curious to know how a 200 wpc 5 channel amp might sound as compared to the LPA-1's 125 wpc, but no one seems to have any experience with that from what I have seen...
    2-channel
  • McLoki
    McLoki Posts: 5,231
    I will say, that after re-reading some of the reviews on the Acurus, some seem to say it is a bright amp. While that would work out ok with the LSi speakers that I have (since they are laid back anyway) it may not be the best match for your RTi's.
    It is supposed to be a very nice amp and you may be very happy with it - but want you to be aware of the potential issue. If you think your speakers are a little on the bright side now - this may push them over the edge. If you consider them neutral to warm (laid back) this may be the perfect amp for you.
    Michael
  • Lowell_M
    dbaldus wrote: »
    I don't notice any difference between the 7000 and 555 in 2 channel. They sound very similar. When watching a movie, though, the addition of the similarly powered center and rear channels really filled the sound in.
    I don't know much about the Emotiva and Acrus amps, but it you found a nice used ADCOM and didn't like it, you can always sell it again and basically you would only be out the shipping.
    With the ADCOM's, I'd bet you would be fine anywhere above 100 wpc. They are very solid amps with tons of headroom for the RTi70's.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • ruf993turbo
    ruf993turbo Posts: 39
    Check out the Adcom amps, they are great...I've had a couple in the past and loved them.
  • NeilGabriel
    NeilGabriel Posts: 1,487
    edited January 2008
    Anybody with specific experience with the Outlaw 750? I'm looking for used and affordable in the 150 wpc range (5 channel). This amp would seem to fit the bill but have never heard any of the Outlaw stuff. Thanks.
