Just got a preamp/amp. Need help!
mhartman29
mhartman29 Posts: 257
I've had my RT5000 system for a few years now and I finally decided it was time to power them properly. After seeing some of the reviews for the Emotiva Ultra HT line, and the price, I decided to take the the plunge.
It hasn't arrived yet, but I'd like to be ready when it does. First I'll need some cables to connect the preouts to the amp. I was looking at http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023602&p_id=2681&seq=1&format=2 these from monoprice, but 3ft seems a bit long. Any other good suggestions?
Also, the LPA-1 amp is described as follows: a Configurable power output as follows: 125 watts/8 ohms x 6 channels or 125 watts/8 ohms x 5 channels plus 2 x 50 watts/8 ohms x 2 channels.
Like I said, I have the RT5000 system, no subwoofer. How would you recommend I connect the speakers? The LPA's user manual says "When connecting the LPA-1 to drive a 7.1 system, you can use channels 1-5 for the
“Main” speakers as you wish, but Emotiva recommends using channels 6 and 7 as the “Rear Back” surround channels so that the power is distributed correctly in the room. This will yield the best results from the front L/C/R speakers and the main surround channels."
Using this setup, won't that mean that the rears (fx1000s) will get 50 watts each to power them? Will this give them enough juice?
Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Analog II ICs
Signal Ultra speaker cables
Post edited by mhartman29 on
  • Face
    Face Posts: 14,340
    edited December 2007
    If you're spending that much on a amp, please get some decent cables. I'd heavily recommend SignalCable, they give a ClubPolk discount also. BJC are a little cheaper, but I hate the terminations they use.
    I used those Monoprice cables briefly, they were a temporary fix until I figured out what lengths I needed. They sound great as long as you don't mind the sound of a blanket thrown over your speakers.
  • mhartman29
    I tried looking at BJC but I couldn't figure out what I needed! Their site is a tad bit complicated for a relative AV/HT novice.
    Looking at signals site, is this what you would use?
    Emotiva LMC pre/pro
    Emotiva LPA amp
    Fronts LSI15
    Center LSIC
    Rears LSI7s
    Dual MFW-15s
    Oppo 980H
  • peffy03
    peffy03 Posts: 50
    oops
    -Jeff
    My System:
    Onkyo Sr604
    Carver 125x2
    Polk Rti 10 (biamped)
    Polk Monitor 30
    Polk psw10bk
    Polk Rti6
    polk CSi3
    Monster ripoff wire
  • peffy03
    peffy03 Posts: 50
    more like
    http://www.bluejeanscable.com/store/6channel/index.htm
    in the options choose 7.1
    -Jeff
    My System:
    Onkyo Sr604
    Carver 125x2
    Polk Monitor 30
    Polk psw10bk
    Polk Rti6
    polk CSi3
    Monster ripoff wire
  • Face
    Face Posts: 14,340
  • mhartman29
    I priced out the following for Signal cables:
    Set of 5 HT analog interconnects (preamp to amp connection): $115
    Ultra speaker wire for 2 front mains and a center channel: $176
    I'm not buying speaker cable for the satellites, yet. That's $291 for cables! Are they worth it?
    Emotiva LMC pre/pro
    Emotiva LPA amp
    Fronts LSI15
    Center LSIC
    Rears LSI7s
    Dual MFW-15s
    Oppo 980H
  • Ricardo
    Ricardo Posts: 10,634
    Signal Cable is worth every penny. Great cables.
    And by the way, Frank gives a 5% discount to Polk forum members.
    SOPA
  • Face
    Face Posts: 14,340
    mhartman29 wrote: »
    Some of us have spent much more than that from Signal. ;)
  • danger boy
    danger boy Posts: 15,722
    mhartman29 wrote: »
    you will not be disappointed if you go with Signal Cables.. they are quite good. and the seller, Frank does give a discount as mentioned above. :D
    PolkFest 2012, who's going>?
  • mhartman29
    I haven't received them, yet, but I went ahead and ordered some Signal cables. Aside from all the advice here, what sealed the deal for me was Frank actually taking time out of his vacation (he's overseas right now) to cell me because I had a few questions I wanted to ask him before ordering.
    That's some customer service! :)
    Emotiva LMC pre/pro
    Emotiva LPA amp
    Fronts LSI15
    Center LSIC
    Rears LSI7s
    Dual MFW-15s
    Oppo 980H
  • ninerbj
    ninerbj Posts: 870
    Excellent! Frank and his products are top notch! enjoy the new set up.
    "she had the body of Venus, with arms."
  • engtaz
    engtaz Posts: 7,672
    reported
    engtaz
