My review of the Denon 3808...
Grimster74
Introduction
Well, as many may know I recently let go of my Outlaw 990 (ohskigod's enjoying it now) and moved to a Denon 3808 (purchased black Friday). My choices came down to the 94 Elite or the 3808 Denon and as you can tell, went with the 3808. I've been in search of a new pre/pro for quite some time to just be able to cut back on having such a rats nest behind all my gear in my a/v cabinet. Well, when I finally realized my humming/buzzing problem had something to do with a bad channel on my Outlaw 7700 amplifier which apparently has been there from day one but I guess the balanced connections I was using helped hide it, what a better time to purchase especially when I have to ship the amp back to Outlaw and without an amp, no way to power the speakers. After reading many reviews of the 94 and the 3808, just the ease of firmware updates via the web, OSD overlay over any signal type and Denons build quality helped me decide.
First Impressions
When I first pulled the 3808 out of the box the first thing I noticed was the sheer weight of the 3808, built like a tank. I know it doesn't way much more than the 94 Elite but the 3808 just seems to have better build quality. After removing the 990 and replacing it with the 3808, now it was time to wire it up. I removed 18 analog cables, 3 fiber optic cables and 1 set of component video cable from the rear of my a/v cabinet. Right now I have 1 cable going to the 3808 from each peice of gear (sat, Blu-Ray, HD-DVD) which is an HDMI cable of course and 1 set of component cables from the Xbox 360. From the 3808 to the projector, a single HDMI cable is all thats hooked up.
Setup
Now that everything is hooked up, time to fire up the gear, keep in mind I have to use the internal amps of the 3808 due to having to send my 7700 back to Outlaw for repair. First I wanted to make sure I had no handshake issues now that all I'm using is HDMI connections, everything works flawlessly. It's just a matter of a second or two before making the HDMI connection, some units have a very slow connection time but not the Denon. Now it was time to go into the menu to assign inputs, speaker sizes, etc. Well one thing I can say for sure is the 3808 has a hell of alot of settings to contend with as well as menus and sub menus. Don't bother to pick up the owners manual cause there is alot to be desired about that which I'll cover later in the review. Well, using Denons remote was a pain in the **** until I figured out how it worked, anyone thats ever used one of Denons touch screen remotes (if thats what it's called) will understand. I think the thing that helped me most was owning a 3805 which has a remote pretty similiar to the 3808.
Assigning inputs and such was pretty self explanatory, knowing all I'd be using was HDMI connections it was just a matter of verifying I had the correct inputs and going with it. I went threw and adjusted all my speaker sizes to small, set all x-over's to 80hz., set all my distances to the sweet spot in the room then adjusted all levels using an analog Radio Shack SPL meter. Once that was done I briefly watched a little of the openinf of Casino Royale to make sure things seemed pretty well balanced and they were. Well after watching the first chapter of the movie, things just didn't sound like they did when I was using the 990/7700 combo but I was pretty sure it had something to do with not having the power going to the speakers that I usually have so I figured I'd give the Audyssey Auto Setup a try.
Audyssey MultEQ
Once the mic was hooked up the OSD shows exactly what the unit is doing as far as setup. The first thing you are told to do is the place the mic in the "MAIN" listening position. This is the centralized position on how the unit calculates your distances and checks speaker polarity. Once this is done you are asked to place the mic in the 2nd position, 3rd position, etc. all the way up to 8 different positions in the listening area. The whole process takes about 1/2 hour as long as there is nothing to disturb the test. Took me 4 times to go threw the whole setup, the first time I quit the setup due to it saying my polarity on my speakers was incorrect which there were correct, the second time the HVAC unit kicked on which threw things off and the third time, beleive it or not, my clock which is hanging on the wall was ticking and it picked up on it. After completely removing all things from the room that made noice, I finally got through the setup.
Once it's done you can check all the settings that the unit calculated. Here is where I got confused, it set my front speakers to large with a x-over of 40hz. and set my distance at 0.8', which when done manually, I have them set at 11.5'. set all my rear speakers to small with a x-over at 80hz and those distances were crazy too. So, instead of trying the setup all over again I figured I'd just save the settings and see how things turned out and I could always go back into the manual menu and make the adjustments manually. To my surprise, this system sounded Amazing other than the subs seemed a tad soft for my taste which I could just bump up with my SMS-1. The front seemed to blend across the room like I've never heard before, it was like everything was right in your face, amazing.
Audyssey Update (12-13-07)
Well, in the past week I've been speaking with a guy from Audyssey to try and figure out exactly why I was getting incorrect readings using the Audyssey MultEQ XT auto setup. Well, I'm happy to say we finally got it figured out and the after effects are absolutely amazing. Apparently, the setup mic on the Audyssey is way more sensitive than I had thought. My first three calculated points in my H/T room were directly under my projector for the most part, apparently the cooling fan within the projector was causing a low hum on the auto setup which totally wacked out my readings. Granted, my fan runs at a low 20db when in echo mode but I had no idea that could throw my readings way off. Yesterday I re-ran the Audyssey using only the front display on the 3808 while the projector was in the off position and everything came back dead on within a inch or two. It still set all speakers to large, full range but I guess thats pretty much a given do to the size of the speakers, I quick change within the manual setup and now I good to go. So, for any of you guys out there having trouble getting the Audyssey to work correctly, keep in mind, your listening enviroment has to be dead "SILENT". All I have to do now is keep my fingers crossed that Outlaw can get my amp back to me within the next week or so that way I can give a review of how the 3808 serves as a pre/amp while I'm on vacation the week after Christmas.
More in a bit...
First Impressions
Setup
Audyssey MultEQ
More in a bit...
Post edited by Grimster74 on
Amp Section
So far I've been pretty pleased with the power the 3808 puts out, it's not my 7700 power plant but the 3808 does quit well. The 3808 gets warm but not near as warm as say the Onkyo's, after watching POC3, which was close to 3 hours long I was able to place my hand on top of the unit and keep it there with no problems. I imagine the heat will be less once I get my 7700 back from repair.
Upscaling
The one thing I don't much care for is the upscaling ability of the 3808. A 1080p signal is passed threw untouched as it should. My HD satellite box going threw the 3808 just seems better if I go directly to the projector. I have all the i/p scalers turned to "OFF" but from what many are saying over at the AVS forum, many think that even if the scaler is in the "OFF" position and the upscaling is set to the "OFF" position, many think the 3808 is still doing some sort of processing. It's not enough of a difference to make me second guess my purchase due to me not watching alot of satellite programming downstairs but I do notice a difference. According to many, now that Denon has been getting many complaints, Denon is looking into the situation that hopefully will be something that can be corrected with a firmware update.
Manual/Remote
The one thing I've come to realize with Denon, they can build one hell of a peice of equipment but the manuals and remotes leave alot to be desired. For a beginner just getting into the H/T, I can see why many newcomers have so many questions and problems gettings things setup. The manual leaves alot out as far as explanations go, like on the i/p scaler, you can set it to "OFF", "A to H", (Analog to HDMI) or "A to H and H to H" (Analog to HDMI and HDMI to HDMI), Denon forgot to explain in the manual what this meant and to be honest with you, took me a few minutes to figure it out. The remote, well I just hate it, after trying to work with it I finally downloaded the file into my URC remote and haven't touched the Denon remote since. What ever happened to just putting a hard buttoned remote in the box, which Denon did for the second room. By far one of the best manuals I've ever had to deal with is Outlaws, everything in the manual is very clear and straight to the point.
Conclusion
Well, so far I'm really enjoying this receiver. I'm really looking forward to getting my 7700 back from Outlaw to see how the 3808 serves as a pre/amp but I'm sure it will still be a couple of weeks before that happens. As for now, I can highly recommend this receiver for anyone looking to move to a new receiver with all the updated features of the 3808. If you looking to upscale alot of sources from 480i, 480p, etc., hopefully Denon will get on a ball and get a firmware update posted for download that will correct this problem. As far as flexability for a receiver, the 3808 I think is where it is at. The new OSD being able to overlay 1080p signals which shows volume control and anything to do with the menus was a big plus for me, being able to rename inputs, assigning different settings to different sources, just about eveything on this receiver was a strong selling point for me. Highly recommended.
Thanks for listening...Money Talks, Mine says Goodbye Rob!!!! -
Nice review; I also got the 3808 to replace my 3803. The added power is VERY noticeable with my RTi8's and CSi5. love it.
Agree on the remote; in fact, I used it for the setup, and still have no idea of how to use it to control the Denon or any other component....luckily I have my Harmony that works so well.
I tried the audyssey setup a few times the first day, but every time the damn dog thought that he had to provide his input and barked!!!. I manually balanced everything, but after your comments I'm gonna try it again._________________________________________________
Tape the dog's mouth shut and lock him in the bathroom
Or just have somebody take him for a walk. -
Very nice conclusion. My Denon 3808 has been sitting in the box for the past few weeks. On one hand, it has all the nice new features (extra input and switching is what I currently don't have. Heck, I don't even have a remote on my current pre). I just can't justify using this as a pre only. Maybe I'll use this to power my other rooms but it's still seem like a waste.Main Gear
Panasonic 50" Plasma, Polk LSi15 (Front), LSiC, LSi7 (Rear), Sherwood Newcastle AVP-9080, AM-9080 bi-amp to LSi15, AM-9080 bi-amp to LSiC and LSi7. -
Nice review nice plug for Denon 3808
Q did you ever try the auto speaker setup with the mic on the PE 84? I found it very nice smooth sound stage over the old method myself, changing nothing else just the AVR itself.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I'm glad your enjoying your Denon. I'm awaiting delivery on a 2308. I hope my setup goes as smoothly as yours.
cubdogShuguang Classic S8MK
Emotiva XDA-2
Bel Canto M300 mono blocks
Bel Canto DAC 1.5
Squeezebox Touch
Sony SS-M7
A/D/S L710 -
Nice informative review Grim! Enjoy.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
After looking over my review, I feel I left alot out of it so if anyone has any questions, please feel free to ask.Money Talks, Mine says Goodbye Rob!!!!
Nice man, I enjoyed the read. Happy to hear you found your humming problem. i knew it was something simple. With the speakers you own, the Denon will keep you happy. Adding the amp may not do to much other then give you more power which you may or may not need.
I'm happy for yeah man,
DanDan
Does the 3808 decode the new surround formats?Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060 -
I'm happy using the 3.6's as my mains with the theater-unity-gain-thruput on the Krell KAV250p preamp (from the Denon). The Denon is quiet enough for home theater purposes and when I want two channel, I just flip channels on the preamp and leave the Denon receiver turned off. When watching DVD/BD, the Denon amp powers the CS400i and the not-so-tiny surround speakers (RT800i's). Some-day, I may add a 3-channel amp and a processer and get rid of the 3801. -
For some setup tips with Audyssey, check my FAQ on it here. It was written for the Onkyo 705, but the majority applies.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
kuntasensei wrote: »For some setup tips with Audyssey, check my FAQ on it here. It was written for the Onkyo 705, but the majority applies.
Thanks so much, damn good reading. I think the thing thats been hurting me most is not having the mic height just above the headrest. I will run it again here real soon as see how my results turn out.Money Talks, Mine says Goodbye Rob!!!! -
LOL! I had to stack a few pillows in my listening chair & put my tripod with the meter attached to it in it! But it worked! Good luckMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
And this is supposed to be simple! -
Grimster74 wrote: »Thanks so much, damn good reading. I think the thing thats been hurting me most is not having the mic height just above the headrest. I will run it again here real soon as see how my results turn out.
Yeah, the headrest can play hell with the equalization. Raising the tripod so it was just above my headrest made a HUGE difference in the overall sound, especially with high-end detail.Equipment list:
Emotiva XPA-3 amp
Actually, it's not. What Audyssey is doing is very complex, and requires some care and common sense when using it. Even with the AVR version, you should follow proper setup and usage just as you would with their significantly more expensive standalone pro version of MultEQ XT to get the desired results. The average non-enthusiast will likely be happy with the end result regardless because they're blissfully unaware... but then, your presence here at the forum pretty means you're teetering into enthusiast territory. Might as well spend a few minutes of self-edyoocayshun and get the most out of your gear!
Equipment list:
Emotiva XPA-3 amp
Thanks for the review. A friend was just looking at those 2 units. Are you still happy with your choice?
Thanks again.
engtazengtaz
Thanks again.
engtaz
Yes Sir, the one thing I'm really looking forward to is getting my amp back, like I said, the Denon holds it's own driving the speakers but I know that the 7700 Outlaw will make it that much better. Outlaw is still a few months out before they release there new pre/pro and chances are I'll end up purchasing that as soon as it hits the market but the one thing that concerns me is like the situation I just had, where the amp went bad and I had to send it in for repair. If I hadn't purchased the 3808, I would have no way to use the H/T for the simple fact that when using the 990/7700 combo, without the amp, no way to drive the speakers. There are both +'s and -'s to using seperates I guess.Money Talks, Mine says Goodbye Rob!!!! -
Updated my review on the Audyssey MultEQ.Money Talks, Mine says Goodbye Rob!!!!
Thanks for the update on setting up using the mic. I decided to keep my 3808 so I started using it and was having the problem with the Audyssey setup. So I am now pretty sure that the culprit is my HTPC fan noise.Main Gear
Make sure you post your findings after rerunning the Audyssey. Like I said, I had no idea something as simple as a cooling fan in a projector could throw it off.Money Talks, Mine says Goodbye Rob!!!! -
Any chance of getting a shot of the innards of this thing? I bet it's impressive under the hood.
FYI: there are some really detailed posts on optimizing the Audyssey over at AVSforums. Audyssey XT is implemented identically in Denon, Onkyo and all the other receivers that license it. I have been following the Onkyo 805 thread there and Chris w/Audyssey actually posts frequently with helpful info.
One thing to note regarding the way Audyssey setup always seems to choose Large speakers even when they are not. According to Chris, its in the way that Denon/Onkyo/etc, implement the bass management. (Audyssey doesn't do bass management) They have chosen to make any speaker that passes frequency below 80Hz to be Large by default. The trick is to just go in and make them small after auto setup. Chris feels that the manufactures should select 40Hz as the cutoff for auto selecting Large. -
Hey Thanks, thats exactly who I've been dealing with but over at HTF. I can never seem to get any answers from AVS when I post a question so thats why I come here first anymore.Money Talks, Mine says Goodbye Rob!!!! -
Well ladies and gentlemen, my Outlaw 7700 came back from repair today and I could not be happier right now. I've been watching TMNT with the boy today and let me tell you this, many have said I may not be able to tell a difference using an external amp compaired to the internal amps of the 3808 but all I can say is WOW. I have a feeling I could stay quite happy for some time right now using the 3808 as a pre/amp. More after I've had a little more time with the setup but so far all things are positive.Money Talks, Mine says Goodbye Rob!!!!
Nice to hear that Grimster, I just bought the 3808 and have the cinenova grande 5 ch to power the LSi speakers. Can't wait to get the stuff in and start setting up. Thanks for starting this thread, I am sure it will help tremendously.Speakers: LSi15 front
Integrated amplifier: NAD 320BEE
Furman PL Plus Series II (line conditioner)
HD DVD A35 Toshiba (Sloooooowwwww to start)
Oppo HD981 (Nice unit) -
Glad to see you back in business Grim! BTW, what is TMNT?Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Teenage Mutant Ninja Turtles:)
