Monster HTS 3600 MKII PowerCenter Users
acsubie
acsubie Posts: 773
edited December 2007 in Electronics
need some feedback from users of the this power center...got it today, hooked it up and everything powered up ok, but the "Clean Power" led on the front display does not light up? i tried using another wall outlet with the same results, anyone experience this? i read the manual but it does not cover this in the troubleshooting section, maybe a burnt LED?
also i had this problem with my other power surge with coaxial in/output but thought maybe the power center could remedy it, if i go with the coaxial cable to the power center IN then OUT to the cable box, some of my HD channels come in scrambled? i had a similar problem last year with the cheaper surge and comcast guy said under no circumstance should you run the cable to a surge, always directly to the box? anyone have success running thru the power center/surge?
  • GSRBOB
    GSRBOB Posts: 172
    I'll check mine out when i get home.
    Onkyo TX-NR801
    Fronts- RTi 10's
    Center- CSi5
    Rear- Coming Soon
    Sub- Velo DPS-10
    Pwr- Monster HTS 3600
    LCD- KDL-40XBR2
  • avguytx
    avguytx Posts: 1,628
    Kind of defeats the purpose of protecting the cable/satellite signal coming in, doesn't it? Have you called Monster customer service per chance? That would be a good thing to do as well.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • shahmichael@com
    shahmichael@com Posts: 55
    I just yesterday hooked up Monster 2600II to my system and ran Direct HDTV coax cables through power center and everything is great,no signal loss,no picture problem,I am very satisfied so far.I was not told by Direct not to run coax through power center.Just a side note I just changed to Direct from Comcast and I ran my cable coax through surge suppressor with no problem.
      PIONEER ELITE 74TXVI-AVR,PARASOUND HCA 1000A-AMP.,JVC SR TS1U S-VIDEO VCR,DENON DCM 460 5DISC CD PLAYER,LUXMAN PD270 DIRECT DRIVE TURNTABLE W/ADC ARM,PA-CS400I CENTER,PA-FXI30 SIDE SURROUNDS,PA-RTI4 REAR SURROUNDS,CERWIN VEGA-211R MAINS,PA-PSW12 SUBWOOFER,BELLO-5TIER RACK,MONSTER WIRING,DIRECT TV HR21-700 HD-DVR,SONY-KP51WS510 51"HDTV,TOSHIBA-A20 HD-DVD PLAYER,ROTEL RB-971 2 CHANNEL AMP,LOGITECH-HARMONY 676 UNIVERSAL REMOTE,MONSTER-2600MKII POWER CONDITIONER
    • acsubie
      acsubie Posts: 773
      spoke to Monster via email, according to them, not having the LED on does not effect the filtering
