fundraiser.......
13»
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited December 2007
    I had around some odd looking crap from the bottom of a bathroom sink drain pipe Tan / Grey in color with no smell, but I'm sure its BIO hazard of some kind I could add to mix.... Price $15 only because it's seemed odd / different. :)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • lightman1
    lightman1 Posts: 10,796
    I've got two cheetos and a half roll of solder on my desk I'll trade for some of that gas, RT. New neighbors up the road are noisy. And an empty cigarette pack to sweeten if you wish. They make great fuse jumpers if the tweet's get to hot.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    LM,
    You will need to acquire the proper over the road EPA clearance, a check with ATF might be in order as well,
    I don't suppose there is any chance the cig pack was smashed in the pocket of Doro's chaps as he paraded around the neighbood on pride day. a major value there.
    RT1
  • BaggedLancer
    BaggedLancer Posts: 6,371
    LM,
    RT1
    Remember you can't travel through tunnels with hazmat either.
  • lightman1
    LM,
    RT1
    I'll check with my CDL Admin in the morning, shouldn't be a problem though. What the ATF don't know won't hurt 'em. Haven't met Doro yet, so the pack is in mint condition otherwise. If Doro shows up at the door with the robe open AND the chaps on... my hearing will eventually become more attuned since I'm sure I will immediately be stricken blind. Compensation thing you know.
    Baggie, no tunnels 'tween here and there. Nothin' but red clay and swamps. Good to go.
  • lightman1
    Anybody need the Cheetos....?
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited August 2011
    Vienna Sausages. We finally opened those and stuck a tooth pick in each one, and set them out at your PF, didn't we Mark?
    I recall one going missing too, someone actually ate one.
