Any Denon 3808 owners out here?
Grimster74
Grimster74 Posts: 2,577
edited December 2007 in Electronics
If so, I have a question concerning S-video signals being sent to a projector only using an HDMI connection, the problem, I can't get a picture. Anyone able to help a Polk brother out I would greatly appreciate it.
Post edited by Grimster74 on
  • fireshoes
    fireshoes Posts: 3,167
    What is the device the s-video connected to?
  • Sherardp
    Sherardp Posts: 8,038
    My guess is youre trying to work with your sms-1. Try running a set of component cables into the AVR. HDMI switching maybe the cause of you not getting a picture. Since its the SMS-1 just run an analog cable.
  • Grimster74
    Sherardp, you are correct. It seems it has something to do with the SMS-1 and not the Denon though according to the AVS forum. For what ever reason, the SMS-1 has a problem with displaying the OSD at 480i while trying to be scaled with the Denon even if I cut the scaling "OFF" within the 3808. Easy solution was to just run a long video cable temporarily to the projector to make the adjustments then remove the cable.
