AWD - Ground Clearance
Sansui
Sansui Posts: 372
edited December 2007 in The Clubhouse
What is the lowest ground clearance a 6 cyl. AWD could have and still "safely" handle in a 10" snow (dry or wet)?
Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN...
Post edited by Sansui on
  • nadams
    nadams Posts: 5,877
    10".
    If you go lower than the height of the snow on the ground, you'll be plowing with it, which will reduce handling. You would also run the risk of getting high-centered at intersections, especially in a wet packing snow.
    I don't have one to measure, but I'm prett sure my dad's subaru isn't 10" off the ground at the front....
    Ludicrous gibs!
  • BaggedLancer
    BaggedLancer Posts: 6,371
    Good question, I'll be able to answer this next winter when my car is about 1.5" lower all the way around.
    Stock my g35 is relatively low to the ground in the front with the little lip. I know I did some plowing last year but the car went right through it.
  • apphd
    apphd Posts: 1,514
    San see my post in your earlier thread
    http://www.polkaudio.com/forums/showpost.php?p=743734&postcount=62
    Again, good luck, I hate auto shopping, but love audio shopping.
  • Serendipity
    Serendipity Posts: 6,975
    nadams wrote: »
    10".
    I'm not too sure, but I'd think 10" also.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Sansui
    Sansui Posts: 372
    apphd wrote: »
    I was "going to go there" next. Guess I'll do that now...
  • John in MA
    John in MA Posts: 1,010
    They're right, about 10" overall. You don't want to be plowing the stuff and if it packed up it's bobsled time. A small something like a differential could hang down lower than that but I wouldn't want much drag in the snow.
    I never was much of a truck guy, but when I got my Jeep I learned just how useless a regular car was on any kind of non-pavement.
    VR3 Posts: 29,397
    Something about plowing the snow with the underbody of any vehicle would scare me...
    And I find cars to be pretty useless all together ;)
  • Sansui
    Sansui Posts: 372
    John in MA wrote: »
    I'm speaking of fresh fallen snow, not packed yet...
  • Sansui
    Sansui Posts: 372
    On the SR5 line skid plates are "standard equipment". ;)
