AWD - Ground Clearance
Sansui
What is the lowest ground clearance a 6 cyl. AWD could have and still "safely" handle in a 10" snow (dry or wet)?
Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN...
Post edited by Sansui on
10".
If you go lower than the height of the snow on the ground, you'll be plowing with it, which will reduce handling. You would also run the risk of getting high-centered at intersections, especially in a wet packing snow.
I don't have one to measure, but I'm prett sure my dad's subaru isn't 10" off the ground at the front....Ludicrous gibs! -
Good question, I'll be able to answer this next winter when my car is about 1.5" lower all the way around.
Stock my g35 is relatively low to the ground in the front with the little lip. I know I did some plowing last year but the car went right through it. -
San see my post in your earlier thread
http://www.polkaudio.com/forums/showpost.php?p=743734&postcount=62
Again, good luck, I hate auto shopping, but love audio shopping. -
10".
I'm not too sure, but I'd think 10" also.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
I was "going to go there" next. Guess I'll do that now...San see my post in your earlier thread
Again, good luck, I hate auto shopping, but love audio shopping.Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN... -
They're right, about 10" overall. You don't want to be plowing the stuff and if it packed up it's bobsled time. A small something like a differential could hang down lower than that but I wouldn't want much drag in the snow.
I never was much of a truck guy, but when I got my Jeep I learned just how useless a regular car was on any kind of non-pavement. -
Something about plowing the snow with the underbody of any vehicle would scare me...
And I find cars to be pretty useless all together
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'm speaking of fresh fallen snow, not packed yet...John in MA wrote: »They're right, about 10" overall. You don't want to be plowing the stuff and if it packed up it's bobsled time. A small something like a differential could hang down lower than that but I wouldn't want much drag in the snow.
I never was much of a truck guy, but when I got my Jeep I learned just how useless a regular car was on any kind of non-pavement.Be gentle, I'm new to all this...
On the SR5 line skid plates are "standard equipment".Vr3MxStyler2k3 wrote: »Something about plowing the snow with the underbody of any vehicle would scare me...
