amplifier hook up
acsubie
i purchased a Emotiva LPA amplifier, i ran a 7.1 system with my Onkyo 805
well i hook up the amp to the onkyo via interconnects, run the audio setup on the Onkyo and its only registering as 5.1 now, the rear surround speakers are not being detected, though they are getting sound, but its the sound from the front L speaker(figured this out by running a test tone thru the seperate channels)
i've read the manuals and cant quite figure it out
anyone have any insight?
Post edited by acsubie on
Check you wire connections again. It has happen to more then 1 person, plugging into the wrong connections. Make sure that you are plugged into the correct pre amp outs and nothing is plugged into the speaker terminals out.
engtazengtaz
Could you have the amp set up wrong? Info from EMO:
"Configurable power output as follows: 125 watts/8 ohms x 6 channels or 125 watts/8 ohms x 5 channels plus 2 x 50 watts/8 ohms x 2 channels"
I do not know much about the LPA1 except what a hear that it is a great audio deal. So I have no idea what is involved with this configuration, if it is a switch or jumper or done with s/w commands. Just an idea, even though that doesn't sound like it would give you signal to them if they are configured for a second zone. -
figured it out after going thru the manual set-up, speakers were set to bi-amp on the receiver
Congrats on figuring it out. Sit back and enjoy.
engtazengtaz
Way to go. Enjoy.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
acsubie, how do you like the lpa?Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Analog II ICs
Signal Ultra speaker cables
