amplifier hook up
acsubie
acsubie Posts: 773
i purchased a Emotiva LPA amplifier, i ran a 7.1 system with my Onkyo 805
well i hook up the amp to the onkyo via interconnects, run the audio setup on the Onkyo and its only registering as 5.1 now, the rear surround speakers are not being detected, though they are getting sound, but its the sound from the front L speaker(figured this out by running a test tone thru the seperate channels)
i've read the manuals and cant quite figure it out
anyone have any insight?
Post edited by acsubie on
  • engtaz
    engtaz Posts: 7,672
    edited November 2007
    Check you wire connections again. It has happen to more then 1 person, plugging into the wrong connections. Make sure that you are plugged into the correct pre amp outs and nothing is plugged into the speaker terminals out.
    engtaz
    engtaz
  • apphd
    apphd Posts: 1,514
    Could you have the amp set up wrong? Info from EMO:
    "Configurable power output as follows: 125 watts/8 ohms x 6 channels or 125 watts/8 ohms x 5 channels plus 2 x 50 watts/8 ohms x 2 channels"
    I do not know much about the LPA1 except what a hear that it is a great audio deal. So I have no idea what is involved with this configuration, if it is a switch or jumper or done with s/w commands. Just an idea, even though that doesn't sound like it would give you signal to them if they are configured for a second zone.
  • acsubie
    acsubie Posts: 773
    figured it out after going thru the manual set-up, speakers were set to bi-amp on the receiver
  • engtaz
    engtaz Posts: 7,672
    edited December 2007
    Congrats on figuring it out. Sit back and enjoy.
    engtaz
    engtaz
  • cfrizz
    cfrizz Posts: 13,415
    Way to go. Enjoy.
  • mhartman29
    mhartman29 Posts: 257
    acsubie, how do you like the lpa?
    Emotiva LMC pre/pro
    Emotiva LPA amp
    Fronts LSI15
    Center LSIC
    Rears LSI7s
    Dual MFW-15s
    Oppo 980H
    Signal Analog II ICs
    Signal Ultra speaker cables
