Def Tech 5.1 Setup
Serendipity
So - I've got Trey's BP10B towers as my main speakers, but I'd like to go with a 5.1 setup. A while back Trey suggested the C/L/R 1000 or C/L/R 2000 center channel, but I am unsure of which rear speakers will match the BP10B best.
Any ideas?
Any ideas?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
I have some, I think they are BP2Xs. They were paired with CLR2002 as center in their original setup.
Got them for my parents, but my Dad decided to go inwalls. The center has been sold, but I've still go these. Been thinking of keeping them for myself since they look so solid, but could be convinced to sell.
They look really good, but I think the tops were touched up somewhere along the way. I can snap some pics, if you like.
Other di/bipoles they have that might match those towers might be BP1.2x and BPX.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Thanks, I may be interested.polkaudio RT35 Bookshelves
where do you live again, Appadv?Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
In that case, I would need to ship them
For some reason, I thought you might be from Tejas. . . please forgive my insolence.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
eh?
Never said I was from Texas, maybe you have me confused with someone else?
hahapolkaudio RT35 Bookshelves
I would suggest a clr 2500 center and bpx surrounds.
That's the powered center, right?
If that's the case, I need to find a looooooooong extension cord
It is powered. It does have it's own amp....Phenom center. Why would you need a long extension cord, if it's centered on your display, reciever, mains, possible sub(s)?...Based on a standard 5.1 setup, where a power source would be available for the center. A power issue might come into play if you were to choose the bpvx, powered surrounds, which is why I chose not to go with them. The bpx surrounds are also phenom surrounds.
