Im I Being Mislead??!!
dellingn
dellingn Posts: 6
I Have Recently Purchased (4) Lc265i And (1) Lci-c Center Speaker.
It Is A Must That I Have In Wall Speaker For My Set Up. I Will Be Using This For Both Home Theater And Music, But Mostly Home Theater. These Speakers Have Not Been Shipped As Of Yet And I Wanted To "exchange" For (5) Tc265i Speakers Wich Are 8 Ohms, But Seller Is Trying To "sway" Me To Keep The Original Purchased Speakers. Is He Just Trying To Make A "more Expensive" Sale At My Expense?
I Am Considering A Denon Avr2808ci Reciever. However The Speakers Are All 4 Ohm And I Am Under The Assumption That This Reciever Will Not Work Well With 4 Ohms, The Reciever Is Rated For 8 Ohm. The Seller Is Assuring Me That I Will Not Have Any Problem And The The 110 Wpc Reciever Will Now Provide 170 Wpc To The 4 Ohm's. Isnt This Over Working The Reciever And Going To Probably Cause Over Heating??? Seller States That He Makes His Living From Installing Home Theaters And That I Am Simply Incorrect And That This Particular Reciever Will Have Absolutely No Problems. Help!!!!!!
Post edited by dellingn on
  • jakelm
    jakelm Posts: 4,081
    edited November 2007
    The Only Problem You Have Is Capitalizing Every Word In Your Sentnce. Very Hard To Read....
    I Have Never Seen A Denon AVR Have Problems With 4OHM Speakers, You Could Always Add External Amps, Via Preouts, If The Load Is Too Much For The Denon...
    ..Welcome To Club Polk....
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • GSRBOB
    GSRBOB Posts: 172
    How much are you paying?
    Onkyo TX-NR801
    Fronts- RTi 10's
    Center- CSi5
    Rear- Coming Soon
    Sub- Velo DPS-10
    Pwr- Monster HTS 3600
    LCD- KDL-40XBR2
  • dellingn
    dellingn Posts: 6
    I can get it only line for around $850-$875
  • bobman1235
    bobman1235 Posts: 10,822
    jakelm wrote: »
    He probably posted in all caps. If every word in your post is all caps, most forums will change it to capitalizing only the first letter of each word for some reason.
  • jakelm
    jakelm Posts: 4,081
    bobman1235 wrote: »
    TESTING TESTING TESTING...ARE ALL MY WORDS COMING OUT IN CAPS...
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • bobman1235
    You Quoted Me Those Words Count
  • jakelm
    jakelm Posts: 4,081
    Ok This Time I Wont Quote You So Lets See If All My Words Come Out In Caps
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    Damn...learn something new every day......Cool
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • GSRBOB
    GSRBOB Posts: 172
    In HT the most important speaker is the center IMO. I say get the better center channel. And the 8 ohm 4 ohm deal is more than likely not a problem. My Onkyo is rated at 6 and 8 ohms on the spec sheet, but yet its hardware setup menu only allows for 4 and 6 ohm. If I could do it again i would have gone with a pre-amp setup.
    Onkyo TX-NR801
    Fronts- RTi 10's
    Center- CSi5
    Rear- Coming Soon
    Sub- Velo DPS-10
    LCD- KDL-40XBR2
  • AndyGwis
    AndyGwis Posts: 3,655
    I don't think it will be a problem to drive the LSiC on the Denon.
    It wouldn't cost you much time, money, or trouble to add an external amp down the road like others have said.
    I don't think you are being led astray by the seller. You agreed to buy one thing and are trying to make a last minute change to something else. I would at least try to appease your worries about the LSiC if I were the seller as well, if only to keep from having to redo the order, maybe repackage the shipment, etc.
    Sounds like a nice start to your setup. The LSiC looks and sounds impressive, so as long as it works size-wise, should be good to go.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • dellingn
    dellingn Posts: 6
  • bobman1235
    GSRBOB wrote: »
    I've heard this a lot and disagree. I've gone 4.1 for several years now (just because of space limitations, nowhere to put the center) and have barely noticed. Obvious exceptions if you sit far outside the nominal viewing area, but if most of your seating is directly in front of the TV you won't even notice your center isn't there.
  • GSRBOB
    GSRBOB Posts: 172
    I guess its arguable bobman.
    Onkyo TX-NR801
    Fronts- RTi 10's
    Center- CSi5
    Rear- Coming Soon
    Sub- Velo DPS-10
    LCD- KDL-40XBR2
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    no its not.
    The Lsi line of in-walls are excellent and are above the Tci in terms of sound quality. I suppose that Denon would be the one to determine if their receiver can drive the speakers. That said its a matter of how much power you put to them.
    I would get the Lsi, I would also seriously consider the performance enclosure's for them if there is any way you can install them.
    RT1
  • Gaara
    Gaara Posts: 2,415
    Some would argue that going with a phantom center is better then having a center. I don't see myself ever going back to a center channel.
    As for the OP, just keep it well ventilated and listen at reasonable volumes and you will be fine.
  • jakelm
    jakelm Posts: 4,081
    It al depends on your mains. If your mains are close enough together, then a phantom center can be achieved. But for most , the mains are too far apart to accomplish a center focal point.
    My system went without a center for a few weeks (while I was building mine) and I was able to achieve a good center phantom channel. But if my mains were any farther apart, it would not have happened.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • bobman1235
    Lasareath wrote: »
    Bob, Does your HT Receiver have a 4.1 setting?
    Yes, they all do. Often called "phantom" mode, because it creates the effect of a phantom center channel, it diverts all the center stuff to the two mains in a way that they seem to be coming from the center. As someone mentioned, this depends on your setup and room geometry, but in my case it works.
  • PolkThug
    PolkThug Posts: 7,532
    Lasareath wrote: »
    My older Onkyo has a phantom center setting which distributes the center channel to the front L/R.
  • AndyGwis
    Most important speaker all depends on what sound format/mode you are listening to.
    If you have 5.1 material playing in 5.1, the center is the most important.
    If you have 5.1 playing in 4.1, it works fine and the fronts are most important.
    I like 5.1 and therefore agree that the center is the most important speaker. With all the different processing modes available, you can pretty much remove any speaker from a setup and be in good shape. Not as good as the material is recorded in, but good enough to listen to. Therefore, if you guys are listening to 5.1 material with a 4.1, I think it will be good, but not nearly as good as if you had a similar quality speaker for the center.
  • jakelm
    jakelm Posts: 4,081
    I know exactly what it is!!!!
    Its the 2chnl guys thinking "if I get a center speaker, I'm not 2chnl anymore, so I'll just stick with only 2 front speakers":p:p:p
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Gaara
    Gaara Posts: 2,415
    jakelm wrote: »
    That could seriously be part of it. Someone spends a lot of time setting up their speakers to sound perfect for 2ch it should sound great for HT to. They already have the speakers positioned perfectly and the perfect amps, it would be a hassle to try and find a center channel to match. Not to mention the additional cost of the speaker + amp.
  • GSRBOB
    GSRBOB Posts: 172
    Good point. I hate the way my all channel stereo preset sounds compared to just my fronts.
    Onkyo TX-NR801
    Fronts- RTi 10's
    Center- CSi5
    Rear- Coming Soon
    Sub- Velo DPS-10
    LCD- KDL-40XBR2
