Buffer cathode followers......
beardog03
beardog03 Posts: 5,550
edited November 2007 in 2 Channel Audio
what are they , and how does it effect the sound ?
I have the Cary F1 SLP 98 and I am getting some tubes to roll in her...
I was told that the two in the middle (line stage) is where the rubber meets the raod (so to speak)....
how important are the other two, and how do they effect the sound ?
I want to put two different tubes in each side, but not sure which ones would work best..
Is this a bad idea ?
example of layout;
folower / follower
output / output
it won`t let me lay it out right....(webpage):mad:
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Post edited by beardog03 on
  • beardog03
    anybody ?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • dorokusai
    dorokusai Posts: 25,576
    Sonic Frontiers and Anthem have generally been mu-follower or cathode follower arrays.
    www.tubecad.com
  • beardog03
    THanks Mark
    you had this unit..
    I`m sure you follow what I`m thinking of...
    Popes in the back (cathode), Hytron in the front (line)...or visa versa
    what do you think ?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • beardog03
    because of the cost of getting two sets of tubes right now, I thing a set of each would work, but if they are not all the same, I may be getting a mixed signal , either way I go...
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • dorokusai
    Yea, that's what I would do....or some variation thereof.
  • beardog03
    New tubes ...they are a`commin !!
    Kevin Deal @ Upscale is THE MAN...!!
    I highly recommend t anyone looking for gear to check out Upscale Audio...
    I also HIGHLY recommend Cary Audio...
    Everybody should have a couple of months listening time on this F1 Version , Pre amp...
    Products Ordered:
    Item name: Electro Harmonix 6SN7
    Grade: Private Reserve [$25]
    Item price: $25.00
    Quantity: 2
    Item name: CBS-Hytron 6SN7GT
    Bought the Gear Here: Platinum Grade [$75]
    Item price: $75.00
    Quantity: 2
    Item name: Pope 6SN7GT
    Item price: $75.00
    Quantity: 2
    It cost me 400 bucks to see which ones I like , but ......
    Hey it was my "B" Day present to myself..!!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
