Cs350
criverajr
I've watched those on ebay for a while. They have been going for less than $150, which is a lot less than they are worth.
This one popped up today for a $139 bin -
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=330191641782&ssPageName=STRK:MEWA:IT&ih=014 -
Damn, if I didn't own two already, I drive over and pick that up. -
Not if I got there first.
These are my stomping grounds broham, only reason it is even up on ebay is it was offered to me first, for much less, and I passed.
You local yokels should be thankful for what actually makes it to ebay in this neck of the woods.
Cheers,
Cheers,
Russ
I'm in DFW until Saturday - what kind of shape is it in?
Do I want a CS350, or a 400 to upgrade from my 300 and pair with my LS-90's? -
You want the 350 to match the drivers. They use the same tweeters (shielded on the center channel), and the woofers are of the same design and construction. -
The 350 is a match on paper, but a horrible center channel via the crossover design.
Stick with the 400 or 300, and the cascaded crossovers, even if the tweeters aren't a spot on match. They are 2nd generation tri-lams and close enough in tonal signature.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Hence my use of electronic crossovers for my LS setup. Easy, pretty cheap upgrade. -
Bumb-a-rooney,
Watching the ones on ebay, let me know would rather buy from a fellow polkie.
CRj -
Main Gear
Panasonic 50" Plasma, Polk LSi15 (Front), LSiC, LSi7 (Rear), Sherwood Newcastle AVP-9080, AM-9080 bi-amp to LSi15, AM-9080 bi-amp to LSiC and LSi7.
