LSIC Speaker Problem?
rencan
rencan Posts: 7
edited November 2007 in Electronics
Should I be hearing sound from both woofers?
I can voices from the right speaker, however only get faint sounds from left woofer. Any ideas as to what could be wrong?
tks,
  • dkg999
    dkg999 Posts: 5,647
    I don't think anything is wrong. If I remember correctly the two mid/woofs are not crossed-over at the same point, so they each produce different frequencies of sound. I would try some music or movies that have a pretty dynamic range of sounds and see if on the lower frequencies the other mid/woof kicks in.
    DKG999
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Welcome to ClubPolk!
    Nothing is wrong....the crossover in the LSi series uses different crossover points in its tiered crossover so that one of the woofers is effectively a mid woofer while the other operates at lower frequencies.
    Edit: Sorry DKG.... you are correct.
  • rencan
    rencan Posts: 7
    Thanks for the quick response, I'll give that a shot.
  • polkatese
    polkatese Posts: 6,767
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    It's a cascaded crossover as DKG said. Some might refer to it as a '2.5 way' speaker.
    Crossover Driver 1: LPF at 200Hz, 12dB/oct.
    Driver 2: LPF at 2.4kHz, 12dB/oct.
    Tweeter: HPF at 2.4kHz, 18 dB/oct.
    One woofer is only playing up to 200Hz, while the other plays up to 2400Hz. This prevents lobing while using mid-bass drivers in a horizontal array, and makes the center sound a WHOLE lot better. If they were crossed over at the same frequency, it would seem louder overall, but sound like hammered ****.
    Welcome to the forum, and thanks for choosing Polk Audio!
    Cheers,
    Russ
    *Edit - lots of quick replies, Polkies are on the ball tonight, good job!*
  • rencan
    rencan Posts: 7
    Thanks for the welcome......I've been reading post for quite a while.
    I've owned the LSI15's for several years now and am still very satisfied with them.
    I bought a 3808 about a month ago; however didn't cross my mind that I may need an AVR that can deliver 4ohms......
    Thanks again everyone.!
