Stereo Sub Recommendations for my Adagios . . .
  • SolidSqual
    SolidSqual Posts: 5,218
    edited November 2007
    Oh . . . gotcha.
    VR3 Posts: 29,425
    Also, its much easier to integrate your mains if you high pass your mains --
    And the x30 takes NOTHING away from the signal that I can hear
    It allows you to easilly do this
  • SolidSqual
    So you use the Crown as a crossover and the x-30 as a high pass filter and volume control
  • dkg999
    dkg999 Posts: 5,647
    Hmmmm, things are sounding pretty good for having non-authentic bass reproduction going on :rolleyes:
    DKG999
    VR3 Posts: 29,425
    Correct --
    the Paradigm is a great crossover to -
    I just like the precision of the Crown's
  • tryrrthg
    tryrrthg Posts: 1,896
    REL Storm III is the best "musical" sub I've ever heard. The cheaper Strata would also be a good choice if you wanted stereo subs.
    ACI Titan or Force are supposed to be great with music also.
  • SolidSqual
    edited December 2007
    Hey,
    What's the buzz on Epik subs? People seem to be recommending them, but I haven't found any reviews. How do they compare with SVS and HSU? They look very similar to sVS other than the 15 inch drivers.
  • Ricardo
    Ricardo Posts: 10,636
    Here's another good option: Von Schweikert VR-S1; small, sealed 10" with a 300W amp. VERY fast and musical. And the finish is beautiful.
    They were discontinued, but there's a guy selling new ones for around $700 each on ebay; reliable seller. he also sells in Audiogon.
    SOPA
