Best IPOD Dock?
SKsolutions wrote: »If you swap the Denon for a new-ish HK, you can fully integrate your iPod. It will charge the pod, play audio AND video. It allows for the remote control of the iPod, and it will emulate the the pod's menus on-screen, and the front panel of the AVR. I may swap down from a 635, down to a 445 so the other half can enjoy the benefits of something more streamlined. The cable gets old after a while, and doesn't charge.
http://harmankardon.com/category.aspx?cat=IPD around 50$ street price.
That's not happening. This is going into a completely separate rig. The denon already has my Accurian Ipod dock with harmony 880 to control the whole setup.
This dock I bought charges, so that's another plus.
Thanks anyway. -
The DLO dock just arrived. Totally awesome product, blows my accurian dock away. The remote is actually heavy and well built rather than the cheap flat ones you usually get. The dock is sturdy and even the cables it comes with aren't that bad.
i have the same product..your post reminded me that the osd is not working. is that because this dock has composite cables into a/v and i have hdmi out to tv . do i need to send composite cables to my tv.. (i guess its not like i dont have a dozen of those laying around) just being lazy.Home Theater
lsi 15's, lsi c, lsi f/x
onkyo 805
sunfire tga 5200
toshiba - xa2
panasonic bd30
sony kdl40v2500
svs sb12+
