Denon or Pioneer...
Grimster74
Grimster74 Posts: 2,577
edited November 2007 in Electronics
If you had to choose a new receiver today to use as a pre-amp, between either the Denon AVR-3808 or the Pioneer Elite VSX-94TXH, which way would you go. Both are at the same price point and both seem to have roughly the same features but it seems the Denon has a lower THD of 0.05% compaired to the Elite which has a THD of 0.09%. Like I said, this will be used as a pre-amp if I decide to purchase so the built-in amplifiers will not be used. Just wanna hear what everyone has to say about the two.
Post edited by Grimster74 on
  • Sherardp
    Sherardp Posts: 8,038
    hard one to go with but I would determine which has features you want. The 94 would get my vote, plus youre using it only has a pre/pro since your Outlaw will be providing the amplification.
  • WilliamM2
    WilliamM2 Posts: 4,806
    If your just going to use it as a pre-amp, why not get a pre-amp instead? The Onkyo PR-SC885 and the Integra 9.8 both have more features, and list for less dollars. The 885 can be had under $1400.
    There is also the new NAD T-175, a little more at $2000, and may not be available till spring.
  • Sherardp
    WilliamM2 wrote: »
    Good suggestion, however the Integra is and has been on backorder for the longest.
  • Grimster74
    WilliamM2 wrote: »
    Because they are almost impossible to get your hands on one. Called my dealer in my area this past Friday about both and he said he's had many on order since October and still has yet to take delivery of any.
  • Mike682
    Mike682 Posts: 2,074
    That difference in THD between the two isn't noticeable to the human ear.
    I heard the Pioneer Elites have very good pre-amp sections; Mantis mentioned he has a lot of experience with Elites:
    http://www.polkaudio.com/forums/showpost.php?p=709882&postcount=26
    Mike
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
    billbillw Posts: 7,495
    I'm a diehard Denon fan, so you can guess my answer. Truth is, you probably can't go wrong with either.
  • WilliamM2
    Grimster74 wrote: »
    Troxell can get you the Onkyo, usually in less than a month. I got lucky, ordered mine 9/21, had it delivered 9/27. Worth a shot.
  • Early B.
    Early B. Posts: 7,900
    Pioneer.
    "God grooves with tubes."
  • mantis
    mantis Posts: 17,329
    Pioneer Elite.
    The 94 is state of the art for a preamp. There is nothing preamp wise on the market yet that can do what it can do. Not to mention as a preamp they sound better then all other receivers I have heard.
    Go Elite man.
    Dan
    Dan
  • Grimster74
    Hey Dan, this is a really stupid question but I figured I'd ask beings your an Elite man, why is it that Pioneer steered away from the removable power cords. Is there some sort of method to there madness. Removable power cords are just so much easier to have when doing an custom install, say in a rack.
  • mantis
    I'm not really sure but I could find out for yeah. I wondered that myself. There DVD players still have removeable cords. Even there brand new 95 elite Blue Ray does(which is the sickest Blue Ray Player on the market hands down).
    Dan
    Dan
  • Grimster74
    Another question, how has Pioneer handled the whole firmware upgrade process with the newer receivers? I know with last years models you had to send them to an authorized Elite dealer to have it done. With the newer Elites having a LAN connection on the back, can the firmware updates if needed be done via the internet?
  • WilliamM2
    mantis wrote: »
    Pioneer Elite.
    Go Elite man.
    Dan
    What features does the Pioneer have that no pre-amp has? Just curious.
  • dorokusai
    dorokusai Posts: 25,576
    Why wouldn't you go with an HT processor?
  • engtaz
    engtaz Posts: 7,669
    Pioneer Elite
    engtaz
    engtaz
  • millerman 3732
    millerman 3732 Posts: 1,488
    Grimster, what the difference in the VSX-94TXH and the VSX-84TXSi you just got rid of?
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
  • Grimster74
    Decodes all the new audio formats as far as i know. Now that I have to updated firmware on my XA2 wanna give it a whirl. The only reason I got rid of the 84 was I was having the humming problem I thought I'd never get figured out which I finally got resolved this past weekend.
