Enough power to run SDA's
NotaSuv
NotaSuv Posts: 3,871
edited November 2007 in Vintage Speakers
Does the B&K AVR 202 have enough power to drive a pair of SDA's.105 at 8 ohms 165 at 6 ohms I believe. Picked up the SDA's that were for sale in St Paul..Seems to be a first gen as all drivers dated 1983, and the 3 prong sda connector..thanks in advance...was going to buy them for my brother but........:)
Post edited by NotaSuv on
  • TroyD
    TroyD Posts: 13,124
    Sure, it has enough power...the SDA's aren't a difficult speaker to drive.
    Now, as to weather and AVR is of sufficient quality to do justice to SDA's is a different question!
    Short answer, is that yes, it will work.
    Welcome!
    BDT
  • NotaSuv
    Thanks Troy...very new to the world of higher end equipt.....have read 100's of pages of posts, and it reminds me of my Jeep addiction,I guess in the end its what makes US happy and this varies widely...have the B&K at my sons house....but am open to suggestions....and again these are virgin ears that have exposed to loud rock for over 30 years;) thanks
  • TroyD
    TroyD Posts: 13,124
    No worries man, the thing is, if you dig it then no one else's opinion really matters.....
    Rock on, broham.
    BDT
  • Systems
    Systems Posts: 14,872
    I'm using B&K mono blocks for the bottom end of the sda 1.2s and a B&K st140 amp to power the tops. this set up plays a s loud as you can stand it! I like nice stuff, but i'm not sure i quite understand it all.
    Testing
    Testing
    Testing
