5.1 Analog connection... the ".1"
Ethancf
Question...
I have 5 Monster Cable Reference 2 1m interconnects connecting my amplifier to my pre/pro and 5 Reference 2's connecting analogs from my XA2 HD DVD player to my pre/pro. I need one cable to cover the .1 LFE.
From my sub to my pre/pro I use an 8' Monster Cable M1000i subwoofer interconnect. To keep things consistent, should I stick with another Reference 2 cable to cover the .1 LFE connection between the pre/pro and HD DVD player or would you suggest something else?
I hate buying a pair of cables when only '1' is needed! :mad:
Thanks!
Thanks!
THE SYSTEM
Polk Audio LSi25 Mains
Polk LSiF/X Surrounds
Polk Audio LSiC Center
Definitive Technology PowerField 1800 Subwoofer
Parasound Classic 7100 Pre/Pro
Parasound 2205A Amplifier
Pioneer Elite BDP-05FD Blu-ray Player
Monster HTS 2600
Microsoft XBox 360
Samsung PN64D550 64" Plasma
Monster HTS 2600
Microsoft XBox 360
Post edited by Ethancf on
If you have booms coming out of your sub, then you are all set!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
You need one more cable or you can drop the 5.1 outputs from the HD-DVD and go straight analog or digital to save money.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I would guess the sub analog IC is probably the least discriminate of all 6. So, get a cheap singe RCA somewhere and try it out, or post what length you need here and I'm sure someone can hook you up (literally) for very cheap.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
