5.1 Analog connection... the ".1"
Ethancf
Question...
I have 5 Monster Cable Reference 2 1m interconnects connecting my amplifier to my pre/pro and 5 Reference 2's connecting analogs from my XA2 HD DVD player to my pre/pro. I need one cable to cover the .1 LFE.
From my sub to my pre/pro I use an 8' Monster Cable M1000i subwoofer interconnect. To keep things consistent, should I stick with another Reference 2 cable to cover the .1 LFE connection between the pre/pro and HD DVD player or would you suggest something else?
I hate buying a pair of cables when only '1' is needed! :mad:
Thanks!
Thanks!
THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma
Post edited by Ethancf on
If you have booms coming out of your sub, then you are all set!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
You need one more cable or you can drop the 5.1 outputs from the HD-DVD and go straight analog or digital to save money.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I would guess the sub analog IC is probably the least discriminate of all 6. So, get a cheap singe RCA somewhere and try it out, or post what length you need here and I'm sure someone can hook you up (literally) for very cheap.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
