5.1 Analog connection... the ".1"
Ethancf
Ethancf Posts: 476
Question...
I have 5 Monster Cable Reference 2 1m interconnects connecting my amplifier to my pre/pro and 5 Reference 2's connecting analogs from my XA2 HD DVD player to my pre/pro. I need one cable to cover the .1 LFE.
From my sub to my pre/pro I use an 8' Monster Cable M1000i subwoofer interconnect. To keep things consistent, should I stick with another Reference 2 cable to cover the .1 LFE connection between the pre/pro and HD DVD player or would you suggest something else?
I hate buying a pair of cables when only '1' is needed! :mad:
Thanks!
THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma
Post edited by Ethancf on
  • cfrizz
    cfrizz Posts: 13,415
    edited November 2007
    If you have booms coming out of your sub, then you are all set!
  • dorokusai
    dorokusai Posts: 25,576
    You need one more cable or you can drop the 5.1 outputs from the HD-DVD and go straight analog or digital to save money.
  • AndyGwis
    AndyGwis Posts: 3,655
    I would guess the sub analog IC is probably the least discriminate of all 6. So, get a cheap singe RCA somewhere and try it out, or post what length you need here and I'm sure someone can hook you up (literally) for very cheap.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
