RM 1000 subwoofer info?
raymillr
raymillr Posts: 6
edited November 2001 in Technical/Setup
Can anyone give me info/specs, dates manufactured, on the RM 1000 subwoofer?
Post edited by raymillr on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello,
    Thanks for your posting on the Forum. The RM1000 was the bass module that was part of the RM3000 satellite/woofer system. The satellites were called the RM2000 II and when combined with the RM1000 you had the RM3000 system. The RM1000 was made available as a separate unit for owners who preferred two bass modules, from 1990 until 1995 and had a suggested retail price of $390.00 each. The RM1000 used two 6.5" drivers and a 10" passive radiator, power handling was 125 Watts/channel, with a frequency response of -3dB from 42 Hz to 200 Hz.
    Regards, Ken Swauger
  • raymillr
    raymillr Posts: 6
    Thanks for the quick reply. Is it a powered subwoofer? are there line inputs, or just speaker inputs? Do you know the dimensions of the box?
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Speaker level inputs, passive sub.
    Not sure on size, I had a spec sheet around here somewhere......
    R
  • [Deleted User]
    Hello,
    The RM1000 enclosure is 12.5" high, 20.25" wide and 13" deep and is not self-powered.
    Regards, Ken
