RM 1000 subwoofer info?
raymillr
Can anyone give me info/specs, dates manufactured, on the RM 1000 subwoofer?
Post edited by raymillr on
Hello,
Thanks for your posting on the Forum. The RM1000 was the bass module that was part of the RM3000 satellite/woofer system. The satellites were called the RM2000 II and when combined with the RM1000 you had the RM3000 system. The RM1000 was made available as a separate unit for owners who preferred two bass modules, from 1990 until 1995 and had a suggested retail price of $390.00 each. The RM1000 used two 6.5" drivers and a 10" passive radiator, power handling was 125 Watts/channel, with a frequency response of -3dB from 42 Hz to 200 Hz.
Regards, Ken Swauger -
Thanks for the quick reply. Is it a powered subwoofer? are there line inputs, or just speaker inputs? Do you know the dimensions of the box?
Speaker level inputs, passive sub.
Not sure on size, I had a spec sheet around here somewhere......
RCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Hello,
The RM1000 enclosure is 12.5" high, 20.25" wide and 13" deep and is not self-powered.
Regards, Ken
