The Composite Cable
Ethancf
All of us certainly know the differences between video cables, but I have to think there are thousands of people that use the composite cable that ships in the box with their HD DVD players...merely because it's there. How many non-calibrated players are running out there with a composite cable...makes me throw up a little bit in my mouth.
:eek:
:eek:
THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma
Post edited by Ethancf on
ignorance is bliss i guess.. the same type of thing where i go over to a friends house with a 50" plasma watching cable over composite (which looks like CRAP on high res lcds or plasma) and he is all proud of himself saying "isnt that picture awsome..its so BIG"..same reason my grandparents bought a 70" lcd projection tv because it is BIG. i am just as big if not a bigger stickler for video as i am audio. most people i know who are "uninformed" about audio/video look at my rti70's and go "wow those are big, they must be awsome" without even giving them a listen..
or no no this is my favorite..like when plasmas first started appearing i had a friend buy a 42" that its resolution was 1024x1024..WTF a plasma "HDTV" in 4:4...riiiiiight..he never even noticed how tall and skinny people looked on his tv
HD DVD players come with composite cables? Mine came with a cheap component + r/l audio cable (5 connectors), but I use HDMI.
Yup...even my 'new' Toshiba XA2 came with a composite/stereo combo cord. Needless to say, they stayed in the package.
THE SYSTEM
Samsung PN64D550 64" Plasma -
amazing how people spend so much moo laa on their TV's then use inferior cables.. ie: composite video. i had a couple friends over recently, they both have standard def TV's... then they got to look at my HDTV (tube) tv with a program broadcasting in 1080i, and their jaws dropped. Needless to say.. they stayed longer than I had hoped.
(i don't use composite or s-video anywhere in my system, component or go home)
PolkFest 2012, who's going>?
And component cables from Signal Cable are quite nice!Michael
NORTH of 60° -
A couple of questions folks.
I currently own a Panasonic RP-56 DVDP and am thinking about a Toshiba XA1 as I own a Panasonic 50" plasma (1080i) and have become accustomed to the great pic quality. My current connection is component cables from the DVDP to the plasma and a digital coax to my Proceed Pre.
Can I use the same cable configuration using the Toshiba.Michael
NORTH of 60° -
Ok, very silly but simple question. In order to view 720p or 1080i do I need to use a HDMI cable or can I use component cables from the DVDP to the plasma. Thanks.Michael
NORTH of 60° -
You can use component to get 1080i from HD-DVD discs using XA1, BUT... This player will only upconvert through HDMI. This means that you will be watching regular DVDs in 480p, not 1080i.
What receiver are you using? In order to get advantage of HD sound from HD-DVDs, you will need a set of analog outs from XA1 to your receiver, unless your receiver has HDMI input.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Thanks.
I am using a Proceed AVP-S. I assume that using a digital out from the DVDP and letting the Proceed convert to analog will not give me HD sound.Michael
NORTH of 60°
