Damn Something.....
alec_d70
Ok, I have a problem. For about the past week now, whenever I have my stereo turned up, and I make a left turn, for about 3 seconds the music will completely shut off. Does not do it on a right turn, nor will it cut off the music when the volume level is lower. Does anybody have any idea what is wrong? Thank you in advance.
Post edited by alec_d70 on
is your turn signal on or off?2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
eloplayspolo wrote: »is your turn signal on or off?
On. I'm not a typical California driver, haha. But how would that affect it? As this only started very recently. -
electrical is complicated but could be something very simple.2013 Toyota Prius
Mosconi 6to8 v8 -
This is a longshot but an easy visual check. Try if you suspect the following may apply.
When I used to install, I came across a speaker wire carelessly run over the steering flex joint instead of the housing above it.
Eventually physical steering wore the wire insulation. Get a flashlight and inspect around the steering knuckle/flexible joint(about straight up from the driver footwell.
The contact with a high output head units speaker lead caused it to self protect since it sensed a direct output short.
Like I said maybe a longshot -
Thats what I was going to say. Chances are the speaker wire is run too close to the steering under the dash.polkaudio sound quality competitor since 2005
Sorry it took so long to reply. But I found just a few topics under mine, about a guy having a similar problem. And mine was solved the same way his was. All I had to do was move around some car alarm wires.
