Damn Something.....
alec_d70
alec_d70 Posts: 5
edited November 2007 in Car Audio & Electronics
Ok, I have a problem. For about the past week now, whenever I have my stereo turned up, and I make a left turn, for about 3 seconds the music will completely shut off. Does not do it on a right turn, nor will it cut off the music when the volume level is lower. Does anybody have any idea what is wrong? Thank you in advance.
Post edited by alec_d70 on
  • eloplayspolo
    eloplayspolo Posts: 1,117
    is your turn signal on or off?
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • alec_d70
    alec_d70 Posts: 5
    On. I'm not a typical California driver, haha. But how would that affect it? As this only started very recently.
  • eloplayspolo
    electrical is complicated but could be something very simple.
    2013 Toyota Prius
    Mosconi 6to8 v8
  • Music Joe
    Music Joe Posts: 459
    This is a longshot but an easy visual check. Try if you suspect the following may apply.
    When I used to install, I came across a speaker wire carelessly run over the steering flex joint instead of the housing above it.
    Eventually physical steering wore the wire insulation. Get a flashlight and inspect around the steering knuckle/flexible joint(about straight up from the driver footwell.
    The contact with a high output head units speaker lead caused it to self protect since it sensed a direct output short.
    Like I said maybe a longshot
  • MacLeod
    MacLeod Posts: 14,358
    Thats what I was going to say. Chances are the speaker wire is run too close to the steering under the dash.
  • alec_d70
    alec_d70 Posts: 5
    Sorry it took so long to reply. But I found just a few topics under mine, about a guy having a similar problem. And mine was solved the same way his was. All I had to do was move around some car alarm wires.
