What should I buy?
Early B.
Pure newb question here 'cause I don't know a damn thing about car audio:
I'm replacing the horrible Bose system in my car with 2 pair of Polk db525 speakers and a Pioneer receiver. My needs are quite simple -- I listen almost exclusively to local radio stations while driving, so I don't need anything fancy. I'm just wondering if what I've purchased is all that I need.
Oh yeah, it helps to know that I won't be cranking it up (too old for that stuff), but I'm most interested in high quality sound. With that in mind, is a separate amp necessary? What about a powered subwoofer?
Thanks.
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
what car do you have?Z
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
KnuKonceptz MKS Kable -
The HU:
I prefer Alpine HUs insted of Pioneer, but Pioneer is actually pretty good...
The coaxials:
The Amp will give your more Sound Quality, the speakers always will sound better with the recomended power, thats why you need the right amp for the inside speakers, most of the time more power means better sound, becouse you dont need to force any component to hear your music at a pretty decent volumen level, that will avoid any kind of distortion.
The frecuency response of your DB525 is 60-22k Hz so the sub would be a really great help.
and the RMS power is 45W on those DB525, so i would recomend a 40 or 50W RMS 4 channel amp.
maybe a pioneer GM-4300F or an Alpine MRP-F250
The Sub:
The powered sub? im not sure, i would buy it separetly, I really think that the separetly components are better, and those powered subs are good but can be better.
for the Sub I would recomend a polk DB104 DVC should be enough (but i dont know much about subs), but it seems like a pretty decent power, and also a nice SQ
and the amp for the Sub should be the same:
Pioneer GM-7300M or an Alpine MRP-M450Z
Polk Audio SR 6500
G35
"God grooves with tubes." -
kommpressorCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
thats a big trunk, maybe you should use a little more power on the bass, but lets wait for more people to post, im not a subwoofer expert...Z
Polk Audio SR 6500
G35
Wow. I just discovered HD Radio!!!
I'm looking at purchasing one of these instead of the Pioneer I ordered:
http://www.dualav.com/receivers/xhd6425.htmlHT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
buy an alpine 9887, is HD radio readyZ
Polk Audio SR 6500
G35
Yo Early! Good to see ya over here dude!
As for needing an amp - its the same as in home audio. The more power the better itll sound. However, if youre just looking for some decent tunes to listen to while you drive to work and back, the head unit will have sufficient power for that.
Same with a sub. One thing to note, those DB's will NOT have as much low frequency response as your current Bose system as theyre designed to work with a sub and not designed to be play full range where as your Bose system was. The midrange and highs will be better but the lows will not. So you could definitely benefit from a sub. As for powered subs there are a few out there. The Infinity Basslink is pretty solid and MTX and Alpine both make good powered subs.
Of course, youll get your best results from a component sub and separate amp but since youre not going for home audio level sound quality the powered subs will work fine.
Here are some good choices.
http://www.crutchfield.com/App/Product/Group/ProductMenu.aspx?g=51000&tp=114
Oh, and stay away from Dual. Shoddy build quality. Stick with the big names for receivers. Pioneer, Alpine, Kenwood, JVC, Clarion and even Panasonic.polkaudio sound quality competitor since 2005
im pretty sure the 9887 still requires the HD adapter2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
yes the Alpine 9887 is HD ready, i mean, it can have HD with the HD adapter TUA-T500HDZ
Polk Audio SR 6500
G35
The Alpine is way beyond my budget. I decided to buy this one:
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=300&i=257KDHDR1&c=3&tp=5684&avf=NHT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
seems like a good value.2013 Toyota Prius
Mosconi 6to8 v8 -
check this:
http://www.amazon.com/Alpine-CDA-9883-MP3-WMA-Receiver/dp/B000OOWGRW/ref=pd_bbs_7/103-8297847-0291846?ie=UTF8&s=electronics&qid=1194416082&sr=8-7
its an Alpine CDA-9883
check the specs here.
http://www.alpine-usa.com/US-en/products/product.php?model=CDA-9883&lang=en&tab=A
and you will need this..
http://www.amazon.com/Alpine-TUA-T500HD-HD-radio-tuner/dp/B000HVVESY/ref=pd_bbs_sr_1/103-8297847-0291846?ie=UTF8&s=electronics&qid=1194416338&sr=8-1
is the HD Module TUA-T500HDZ
Polk Audio SR 6500
G35
you would use the
50Wx4 Max power if you dont use an amp
the crossover for giving the right frecuency to the inside speakers, and the sub, so every speaker should have the correct frecuency and they will sound at the best performance. (so important in SQ)
Ipod Ready you probably have an Ipod, so the cable is just $17 bucks on amazon
3 pre outs front ones, rear ones and subwoofer, and you can regulate the power of the sub from your HU
And comparing this JVC with the Alpine CDA-9883
power same
frecuency response, 40-20k vs 20 a 20k on the alpine
sub pre amps same
EQ 7 bands JVC none Alpine (i have the 9887 with EQ and i really dont use it, sometimes sounds better in flat)
HD radio JVC built in vs Alpine optional
Bluetooth JVC none vs Alpine optional
I know what are you saying "Alpine is expensive becouse everything is optional" but come on, you are not going to buy all the options, just the ones you need, and the sound is awesome and is one of the best brands in HUsZ
Polk Audio SR 6500
G35
the jvc has a built in hd tuner, its a very good deal. there is a big price diffrent kinetic and for him, its prob not worth it.2013 Toyota Prius
Mosconi 6to8 v8 -
Early, you better high tail it back to 2 channel before these guys pull you into the dark side.
I dunno, its a lot cheaper over here!
That JVC is a solid piece Early. Its got a 7 band graphic EQ which aint great but is just fine for your needs. It has several presets in case you dont want to mess with it but it allows enough flexibility in case you get the itch to fidget with it.
It doesnt have a crossover tho but most dont and again, for your needs its ok.polkaudio sound quality competitor since 2005
madmax
Too late.
I got everything installed this morning -- Polk 5.25" front speakers, Alpine 6.5" speakers in the rear, and the JVC head unit. Sounds OK, not great (yet). Bass is weak. maybe the equalizer will help. I'm using the presets right now. I still have to learn how to tweak this thing, though. A couple of my favorite radio stations broadcast in HD, but the signal is not as strong as regular radio (yet).
I was gonna install everything myself, but then I glanced at the instructions for the head unit (or lack thereof) and said, "'Eff it!" I'm not gonna attempt it. However, I ripped out the cheap, $3-looking Bose speakers.
Man, this stuff can get expensive very quickly. So far I've spent over $400 just to get better radio perfomance. WTF am I doing?!! :eek: I'd really like a separate amp and subwoofer, but it ain't gonna happen. That's just too much money. Now I see why some people are really into car audio.
I promise -- I won't get pulled to the dark side.;)HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Hope you can figure out how to tweak it and are satisfied with it!
But, you should join the dark side! I have about $1100 in my system...and don't even have a sub! :eek: It's a pity...I NEED a sub...and new speakers, for that matter...
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
I have a $2800 amp.
-CodyMusic is like candy, you have to get rid of the rappers to enjoy it
