What should I buy?
Early B.
Early B. Posts: 7,900
edited November 2007 in Car Audio & Electronics
Pure newb question here 'cause I don't know a damn thing about car audio:
I'm replacing the horrible Bose system in my car with 2 pair of Polk db525 speakers and a Pioneer receiver. My needs are quite simple -- I listen almost exclusively to local radio stations while driving, so I don't need anything fancy. I'm just wondering if what I've purchased is all that I need.
Oh yeah, it helps to know that I won't be cranking it up (too old for that stuff), but I'm most interested in high quality sound. With that in mind, is a separate amp necessary? What about a powered subwoofer?
Thanks.
"God grooves with tubes."
Post edited by Early B. on
  • Kinetic
    Kinetic Posts: 437
    what car do you have?
    Z
    /////Alpine CDA-9887 HU
    /////Alpine KTX-1000EQ
    /////Alpine PDX-4.150
    /////Alpine PDX-1.1000
    Polk Audio SR 6500
    Polk Audio SR 124 DVC
    KnuKonceptz MKS Kable
    G35
    /////Alpine SPX 17PRO
    /////Alpine SWX 1243D
  • Kinetic
    Kinetic Posts: 437
    The HU:
    I prefer Alpine HUs insted of Pioneer, but Pioneer is actually pretty good...
    The coaxials:
    The Amp will give your more Sound Quality, the speakers always will sound better with the recomended power, thats why you need the right amp for the inside speakers, most of the time more power means better sound, becouse you dont need to force any component to hear your music at a pretty decent volumen level, that will avoid any kind of distortion.
    The frecuency response of your DB525 is 60-22k Hz so the sub would be a really great help.
    and the RMS power is 45W on those DB525, so i would recomend a 40 or 50W RMS 4 channel amp.
    maybe a pioneer GM-4300F or an Alpine MRP-F250
    The Sub:
    The powered sub? im not sure, i would buy it separetly, I really think that the separetly components are better, and those powered subs are good but can be better.
    for the Sub I would recomend a polk DB104 DVC should be enough (but i dont know much about subs), but it seems like a pretty decent power, and also a nice SQ
    and the amp for the Sub should be the same:
    Pioneer GM-7300M or an Alpine MRP-M450
    Z
    Polk Audio SR 6500
    G35
  • Early B.
    Kinetic wrote: »
    Mercedes C-280.
  • beardog03
    beardog03 Posts: 5,550
    kommpressor
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Kinetic
    Kinetic Posts: 437
    thats a big trunk, maybe you should use a little more power on the bass, but lets wait for more people to post, im not a subwoofer expert...
    Z
    Polk Audio SR 6500
    G35
  • Early B.
    Wow. I just discovered HD Radio!!!
    I'm looking at purchasing one of these instead of the Pioneer I ordered:
    http://www.dualav.com/receivers/xhd6425.html
  • Kinetic
    Kinetic Posts: 437
    buy an alpine 9887, is HD radio ready
    Z
    Polk Audio SR 6500
    G35
  • MacLeod
    MacLeod Posts: 14,358
    Yo Early! Good to see ya over here dude!
    As for needing an amp - its the same as in home audio. The more power the better itll sound. However, if youre just looking for some decent tunes to listen to while you drive to work and back, the head unit will have sufficient power for that.
    Same with a sub. One thing to note, those DB's will NOT have as much low frequency response as your current Bose system as theyre designed to work with a sub and not designed to be play full range where as your Bose system was. The midrange and highs will be better but the lows will not. So you could definitely benefit from a sub. As for powered subs there are a few out there. The Infinity Basslink is pretty solid and MTX and Alpine both make good powered subs.
    Of course, youll get your best results from a component sub and separate amp but since youre not going for home audio level sound quality the powered subs will work fine.
    Here are some good choices.
    http://www.crutchfield.com/App/Product/Group/ProductMenu.aspx?g=51000&tp=114
    Oh, and stay away from Dual. Shoddy build quality. Stick with the big names for receivers. Pioneer, Alpine, Kenwood, JVC, Clarion and even Panasonic.
  • eloplayspolo
    eloplayspolo Posts: 1,117
    im pretty sure the 9887 still requires the HD adapter
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • Kinetic
    Kinetic Posts: 437
    yes the Alpine 9887 is HD ready, i mean, it can have HD with the HD adapter TUA-T500HD
    Z
    Polk Audio SR 6500
    G35
  • Early B.
    The Alpine is way beyond my budget. I decided to buy this one:
    http://www.crutchfield.com/App/Product/Item/Main.aspx?g=300&i=257KDHDR1&c=3&tp=5684&avf=N
  • eloplayspolo
    seems like a good value.
    2013 Toyota Prius
    Mosconi 6to8 v8
  • Kinetic
    Kinetic Posts: 437
    Z
    Polk Audio SR 6500
    G35
  • Kinetic
    Kinetic Posts: 437
    you would use the
    50Wx4 Max power if you dont use an amp
    the crossover for giving the right frecuency to the inside speakers, and the sub, so every speaker should have the correct frecuency and they will sound at the best performance. (so important in SQ)
    Ipod Ready you probably have an Ipod, so the cable is just $17 bucks on amazon
    3 pre outs front ones, rear ones and subwoofer, and you can regulate the power of the sub from your HU
    And comparing this JVC with the Alpine CDA-9883
    power same
    frecuency response, 40-20k vs 20 a 20k on the alpine
    sub pre amps same
    EQ 7 bands JVC none Alpine (i have the 9887 with EQ and i really dont use it, sometimes sounds better in flat)
    HD radio JVC built in vs Alpine optional
    Bluetooth JVC none vs Alpine optional
    I know what are you saying "Alpine is expensive becouse everything is optional" but come on, you are not going to buy all the options, just the ones you need, and the sound is awesome and is one of the best brands in HUs
    Z
    Polk Audio SR 6500
    G35
  • eloplayspolo
    the jvc has a built in hd tuner, its a very good deal. there is a big price diffrent kinetic and for him, its prob not worth it.
    2013 Toyota Prius
    Mosconi 6to8 v8
  • madmax
    madmax Posts: 12,434
    Early, you better high tail it back to 2 channel before these guys pull you into the dark side. :)
    madmax
    Vinyl, the final frontier...
  • MacLeod
    I dunno, its a lot cheaper over here! ;)
    That JVC is a solid piece Early. Its got a 7 band graphic EQ which aint great but is just fine for your needs. It has several presets in case you dont want to mess with it but it allows enough flexibility in case you get the itch to fidget with it.
    It doesnt have a crossover tho but most dont and again, for your needs its ok.
  • Early B.
    madmax wrote: »
    madmax
    Too late.
    I got everything installed this morning -- Polk 5.25" front speakers, Alpine 6.5" speakers in the rear, and the JVC head unit. Sounds OK, not great (yet). Bass is weak. maybe the equalizer will help. I'm using the presets right now. I still have to learn how to tweak this thing, though. A couple of my favorite radio stations broadcast in HD, but the signal is not as strong as regular radio (yet).
    I was gonna install everything myself, but then I glanced at the instructions for the head unit (or lack thereof) and said, "'Eff it!" I'm not gonna attempt it. However, I ripped out the cheap, $3-looking Bose speakers.
    Man, this stuff can get expensive very quickly. So far I've spent over $400 just to get better radio perfomance. WTF am I doing?!! :eek: I'd really like a separate amp and subwoofer, but it ain't gonna happen. That's just too much money. Now I see why some people are really into car audio.
    I promise -- I won't get pulled to the dark side.;)
  • audiobliss
    audiobliss Posts: 12,518
    Hope you can figure out how to tweak it and are satisfied with it!
    But, you should join the dark side! I have about $1100 in my system...and don't even have a sub! :eek: It's a pity...I NEED a sub...and new speakers, for that matter...
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • exalted512
    exalted512 Posts: 10,735
    I have a $2800 amp.
    -Cody
