Toshiba HD-A2 Sound Level
fatchowmein
I noticed the volume level on my A2 is noticably lower than any other component I have. Movies on other players are/were typically played at -38 to -43. I usually play the A2 at -32. Is anyone else noticing this?
My A2 is hooked up via optical. I've tried both the Bitstream and PCM settings.
Post edited by fatchowmein on
I just hooked mine up through optical yesterday and I'm running at about the same sound level on CD's. My daughter and I are having movie night tonight(Spidey 3 and Transformers) so I'll see then as far as movies.
i believe the lower volumes are inherent with hd dvd. try playing a standard dvd and see if it's any 'louder'. all i do is just turn up the volume a bit whilst playing hd dvd's.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
fatchowmein wrote: »I noticed the volume level on my A2 is noticably lower than any other component I have... Is anyone else noticing this?
Yes.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Ditto. No biggie but I did notice that I had to take the level up a decent chunk. On my Integra receiver, it was usually at a reading of 40...now it seems like I have to get it to around 50 or so.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
I wasn't sure if I bought a dud. Thanks for the replies.
Some with my A30. I had to watch movies such as Transformers with 5 registered on my Onkyo Vs 15 registered for every BR I play.Testing
Testing
Testing -
Much lower noise levels in HD sound... Also, notice that there is no bass, so you will have to lower all channels in the setup, and leave sub at zer0.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
