Toshiba HD-A2 Sound Level
fatchowmein
fatchowmein Posts: 2,637
edited November 2007 in Electronics
I noticed the volume level on my A2 is noticably lower than any other component I have. Movies on other players are/were typically played at -38 to -43. I usually play the A2 at -32. Is anyone else noticing this?
My A2 is hooked up via optical. I've tried both the Bitstream and PCM settings.
Post edited by fatchowmein on
  • daboyz
    daboyz Posts: 5,207
    I just hooked mine up through optical yesterday and I'm running at about the same sound level on CD's. My daughter and I are having movie night tonight(Spidey 3 and Transformers) so I'll see then as far as movies.
  • BIZILL
    BIZILL Posts: 5,432
    i believe the lower volumes are inherent with hd dvd. try playing a standard dvd and see if it's any 'louder'. all i do is just turn up the volume a bit whilst playing hd dvd's.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • Early B.
    Early B. Posts: 7,900
    I noticed the volume level on my A2 is noticably lower than any other component I have... Is anyone else noticing this?
    Yes.
    "God grooves with tubes."
  • avguytx
    avguytx Posts: 1,628
    Ditto. No biggie but I did notice that I had to take the level up a decent chunk. On my Integra receiver, it was usually at a reading of 40...now it seems like I have to get it to around 50 or so.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • fatchowmein
    I wasn't sure if I bought a dud. Thanks for the replies.
  • Systems
    Systems Posts: 14,872
    Some with my A30. I had to watch movies such as Transformers with 5 registered on my Onkyo Vs 15 registered for every BR I play.
    Testing
    Testing
    Testing
  • ViperZ
    ViperZ Posts: 2,046
    Much lower noise levels in HD sound... Also, notice that there is no bass, so you will have to lower all channels in the setup, and leave sub at zer0.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
