Looking for a good $250 Sub
gacole2000
gacole2000 Posts: 255
edited February 2003 in Flea Market
I'm looking for a good sub in the $200-300 range. Thanks
AVR: Yamaha RX-V661
DVD: Yamaha DV-C6480
BR: Samsung 1600
Mains: Polk RT55 (bi-amped)
Center: CS300
Sides: FX1000
Rears: RT/FX
Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
Projector: Optoma HD70 w/ 106" Elite Screen
Power: Panamax MAX 5100
Remote: Harmony One
Post edited by gacole2000 on
  • goingganzo
    goingganzo Posts: 2,793
    i have a good sub selling for 250+shiping it might be sold or not? i have not herd back from a fellow polk member if he dont buy it and you still want it it is all yours.
    velo ct120
  • RuSsMaN
    RuSsMaN Posts: 17,985
    So who were you going to buy from, me or Ganzo, or both?
    Just curious.
  • gacole2000
    Russman, I'm not sure what your message means?
    Ganzo, I just picked up a new DVD player, so I can't do anything just yet. However, I am interested. They have that model at CC, that I could go listen to, correct? Further, where would it be shipped from and how much does it weigh? Thanks for your post, I appreciate it. I will keep you informed.
    Greg
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
  • RuSsMaN
    Greg, that was directed towards ATC. I should have made that clear.
    Cheers,
    Russ
  • goingganzo
    i dont mind waiting i dont need the cash right now. check out the velo cht-12 their curent moddle but it is the same woofer and amp as befor. just new box. it will cost 50 bucks for shiping max. weights 60lbs.
  • MxStYlEpOlKmAn
    MxStYlEpOlKmAn Posts: 2,116
    Originally posted by ATCVenom
    Russ,
    The plan was - there was no plan in the first place.
    My plans...were to make plans that would never turn into plans therefore the plan was to make a non-futuristic plan that would involve nothing but my imagination to make a plan to make a plan that would never exist to start with. Therefore - there was a plan to make no plan. figure that out einsteins.
    Damn you all, damn you all to hell.......
    I promised myself
    Damn you all! - ATC
