Corsair TwinX1024-PC3200 Gaming Ram
Refefer
Hey guys,
I've needed to upgrade my memory amount due to my home computer being converted into a video production machine, and this ram has to go. Being limited to two DIMM slots, I've been forced to buy a couple of 2GB sticks to replace the 2 x 512 stick of this ram.
This is the fastest ram you can buy for DDR400 systems. Highly worth it and I regret having to sell it off: If I could keep it I would.
Word of caution: This ram is grumpy as hell when trying to work with other, slower sticks of memory. Use this exclusively or match it with other TwinX series of ram.
It originally cost me about $300, and buying it new right now is looking to be about $120. I figure $60 shipped to your door would be fair.
Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II
Polk SDA-1B,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
Computer Rig
Polk SDA CRS+,
Post edited by Refefer on
For those of us slower than average - what you are selling is 2 512meg sticks correct?Mains.............Polk LSi15 (Cherry)
Just out of curiousity, what're the timings for the RAM and the voltage?
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
That is correct. 2x 512mb Dimms.audiobliss wrote:Just out of curiousity, what're the timings for the RAM and the voltage?
Timings are officially at 2-3-3-6, I was able to get it to 2.5-3-3-6 at around 2.7 volts if I recall correctly. I only upped it when playing heavy games and normally ran it (and my cpu) at normal speeds, which I believe is 3-3-3-8. It should be mentioned that it had room to be pushed further if you really wanted to tinker with it, but waiting 24 hours each time you make an adjustment to run tests on it took too long
Polk SDA-1B,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
Computer Rig
Polk SDA CRS+,
HRT Music Streamer II -
I'm an idiot. Totally didn't read things right.
Good luck with your sale!!
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
just fyi lower ram timings is better so an official timing of 2-3-3-6 is better than 2.5-3-3-7. good ram none the less
Indeed it is, but when overclocking it's speed from DDR400 to DDR450, it's stability drops significantly.Lovin that music year after year.
Polk SDA-1B,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
Computer Rig
Polk SDA CRS+,
