Damage?
Jockos
Jockos Posts: 310
edited February 2003 in Troubleshooting
My yamaha puts out 80 watts per channel. As too the question if this was a unusually loud setting I have listened to it louder but with my monitor 8T's and 11T's hooked up. Unfortunately I use these in the living room. My bedroom HT uses the smaller 5B's. The thing that worries me is that un godly sound it made. I wonder if the voice coil either bottomed out or came out of the gap. I have pushed the 5B's hard on music and they have a slight poping sound on the passive radiator/or 6 half driver when they reach their limit. Never heard a sound like that before. I believe it must be the LFE on that Lift off scene, that does not occur on normal music material. I just hope their is no pemanant damage or degradation.
Post edited by Jockos on
  • MxStYlEpOlKmAn
    MxStYlEpOlKmAn Posts: 2,116
    Im not sure bout nething man, but my yammer puts out 100 and it cant drive my speakers past 32.5 without squealing.
    Damn you all, damn you all to hell.......
    I promised myself
    Damn you all! - ATC
