Benz Micro Silver Cartridge.
hearingimpared
For Sale; A Benz Micro Silver Cartridge, under seven hours of use. It is pretty much brand new. Original box and instructions.
New: $350
$165 shipped. Postal Money order.
This was my backup cartridge, I'm selling it because I just purchased a new cartridge and am using my Dynavector as my backup.
Look online and read the excellent reviews.
New: $350
Post edited by hearingimpared on
bump
Price reduced!
Bump
bump
Might be a good time for ONE new thread, with all your warez that haven't moved yet.
Cheers,
Cheers,
Russ
Great idea; thanks for the tip! -
Price reduced!
Price Reduction, on Agon for a lot more.
Does anyone know if this will fit an old AR XB turntable??????2 Channel:
Amp/Parasound Halo A23
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Turntable/AR XB-Shure V15 III -
Here is a pic of the underside. If your AR headshell has two cartridge mounting holes and four tonearm cartridge wire, it should fit. The only thing I advise you to do is find out what weight and compliance the tonearm requires of its match with a cartridge.
Joe- You are approaching "giving away" price.
I keep looking at this 5.7 gr cartridge and think of my 6.0gr minimum tonearm specs.....damn....._________________________________________________
Nibble........Nibble
This sure would sound good on my Micro Seiki, 0-4 gram tracking, 4-11 gram cart wt. Do you think this would be a match?>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Does your tonearm list a range of cartridge compliances that it matches with? I.e. low to medium compliance or medium to high compliances?
Ric you may want to check with the dealer about that. .3 gms of anything with a cartridge especially with VTF can be heard. But I don't know how much of an affect it can with cartridge weight on a tonearm. -
hearingimpared wrote: »Here is a pic of the underside. If your AR headshell has two cartridge mounting holes and four tonearm cartridge wire, it should fit. The only thing I advise you to do is find out what weight and compliance the tonearm requires of its match with a cartridge.
I'm pretty sure it will physically fit the head shell,,what I'm not sure of is the weight and compliance the tonearm requires. I've been checking around the web and found a lot of info but not what I'm looking for! What I could really use is a new stylus for my Shure V15 III cartridge but they are very hard to find and cost an arm and a leg. I'll keep looking and maybe I'll find the specs.2 Channel:
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Sale Pending.
