Benz Micro Silver Cartridge.
hearingimpared
hearingimpared Posts: 21,136
edited November 2007 in For Sale (FS) Classifieds
For Sale; A Benz Micro Silver Cartridge, under seven hours of use. It is pretty much brand new. Original box and instructions.
New: $350
$165 shipped. Postal Money order.
This was my backup cartridge, I'm selling it because I just purchased a new cartridge and am using my Dynavector as my backup.
Look online and read the excellent reviews.
Post edited by hearingimpared on
  • hearingimpared
    edited July 2007
    bump
  • hearingimpared
    edited July 2007
    Price reduced!
  • hearingimpared
    edited July 2007
    Bump
  • hearingimpared
    edited July 2007
    bump
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited July 2007
    Might be a good time for ONE new thread, with all your warez that haven't moved yet.
    Cheers,
    Russ
  • hearingimpared
    edited July 2007
    RuSsMaN wrote: »
    Cheers,
    Russ
    Great idea; thanks for the tip!
  • hearingimpared
    edited September 2007
    Price reduced!
  • hearingimpared
    Price Reduction, on Agon for a lot more.
  • Roy Munson
    Roy Munson Posts: 886
    Does anyone know if this will fit an old AR XB turntable??????
    2 Channel:
    Amp/Parasound Halo A23
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
    Turntable/AR XB-Shure V15 III
  • hearingimpared
    Here is a pic of the underside. If your AR headshell has two cartridge mounting holes and four tonearm cartridge wire, it should fit. The only thing I advise you to do is find out what weight and compliance the tonearm requires of its match with a cartridge.
    benz.JPG 307.9K
  • capecodder
    capecodder Posts: 613
    Joe- You are approaching "giving away" price.
  • Ricardo
    Ricardo Posts: 10,634
    I keep looking at this 5.7 gr cartridge and think of my 6.0gr minimum tonearm specs.....damn.....
    SOPA
  • Polkersince85
    Polkersince85 Posts: 2,883
    Nibble........Nibble
    This sure would sound good on my Micro Seiki, 0-4 gram tracking, 4-11 gram cart wt. Do you think this would be a match?
  • hearingimpared
    Does your tonearm list a range of cartridge compliances that it matches with? I.e. low to medium compliance or medium to high compliances?
  • hearingimpared
    Ricardo wrote: »
    Ric you may want to check with the dealer about that. .3 gms of anything with a cartridge especially with VTF can be heard. But I don't know how much of an affect it can with cartridge weight on a tonearm.
  • Roy Munson
    I'm pretty sure it will physically fit the head shell,,what I'm not sure of is the weight and compliance the tonearm requires. I've been checking around the web and found a lot of info but not what I'm looking for! What I could really use is a new stylus for my Shure V15 III cartridge but they are very hard to find and cost an arm and a leg. I'll keep looking and maybe I'll find the specs.
    2 Channel:
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
  • hearingimpared
    Sale Pending.
