Suspect Squirrel In My Attic! *#%!!
Beekyman
Ok folks, anyone have their attic space invaded by that no good, nut eatin', bushytailed rodent that we all know as the North American Grey Squirrel? In the spirit of Halloween there is indeed something that goes "bump" in the night and in the wee hours of the morning I can hear his chewing, gnawing, scurrying around up over my bedroom! Cant sleep!
I know that he has been there, little squirrel turds (about the size of a Tic Tac) are in the suspected location along with the some of the house that he has been remodeling for me!
Last winter I first had this issue and hired an exterminator to catch the little bugger. They never did catch him but they did fix the holes he created and attempted to block any entry points into the attic space. Now he has returned to settle in for winter...Squirrel must DIE!
I have set two traps baited with corn cobs and peanut butter in the suspected area of squirrel operations in the hopes of getting rid of the problem myself. Does anyone have any good insight on how to eliminate the squirrel problem and how to discourage other like minded squirrels from setting up shop in my attic? Any suggestions funny and serious are appreciated!
2 Channel Rig
Source 1 - Apple TV
Source 2 - Parasound D3 Universal Player
Source 3 - Parasound Tuner T3
Pre-amp - Parasound HALO P3
Amplifier - Parasound HALO A21
Speakers - Martin Logan Vista
Power Conditioning - Panamax M5100-EX
Source 1 - Apple TV
Try some of that green colored poison they sell for mice and such. Had a problem with mice at an old farm house outside of Richmond and that stuff killed anything that ate it including a squirrel.
Wont it die in the attic causing a big stink?
Thanks for the quick reply!2 Channel Rig
Source 1 - Apple TV
Power Conditioning - Panamax M5100-EX -
Yep, sure will. You did want it dead right....LOL.
If you can get up there, you shouldn't have a problem finding it, just follow your nose. -
Different ways:
1. Wait until squirrel is out and plug the holes
2. Trap squirrel and plug the holes
3. (my choice) Shoot squirrel and then plug the holes. Eating squirrel is optional
Regardless of what you do, the holes must all be solidly plugged. Even if that means heavy wire mesh or cement. -
Don't look at me -- I just dealt with a squirrel in my chimney (again).
I just let it die and fished out the dead remains before it started stinking up the place. A new chimney cap was also added.
Try moth balls.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
When you hear his little arse moving around up there take a large mean housecat and introduce him to the squirrel, if the cat doesnt get him and he runs out that's when you blast his lil **** with a shotgun.
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Mothballs will work though they smell aweful, agree use some kind of poison then fish him out. Or call pest control and see what they can do.Shoot the jumper.....................BALLIN.............!!!!!
John in MA wrote: »Different ways:
LMAO optinal I love when the answer to to the problem involves a SHOT GUN. Hilarious. I can rent you my cat she loves to KILL thingsHT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Get ya an alley cat, put the cat in the attic and let the fun begin."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
mesh wire..
aligator clips (heavy duty)
spool of insulated wire
30 amp breaker
nuts
fire extinguisher
small body bag w/ tiny toe tag for victim, err...... intruder
intruder, yeah , that what I meant to sayCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
bigaudiofanatic wrote: »LMAO optinal I love when the answer to to the problem involves a SHOT GUN. Hilarious. I can rent you my cat she loves to KILL things
Shotguns are too crude for this. I'd recommend a high power pellet rifle. -
Call Bullwinkle. Tell him Rocky's smoking acorns again.I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff.
