Popping and screaching
gidrah
I recently bought a new (to me) equalizer and amp.
I bought the EQ from George and the amp from E-bay. The EQ is wonderful and was well packed, as was the amp. When I hooked them up the result was a happy Gidrah. The EQ did what was expected and the Soundcraftsman amp has plenty of power for my little bookshelfs. I also noticed that the Soundcraftsman is absolutely quite compared to the slight hiss of the previous the previous amp. Sorry Bob, but it looks like you'll be bridged and driving the sub when I build it.
The popping and screaching was probably from the bubble-wrap and styrofoam.:D
Make it Funky!
Post edited by gidrah on
i am curious, just how many people in here use EQ's in their systems? I know what EQ's do and how they work. but what benefits do you get by adding a EQ? And will an EQ "taint" or "color" the sound?PolkFest 2012, who's going>?
Popping and Screeching, eh... someone wanted a little attention. Bad gidra, bad now go to your room
I know this is 2 ch land, but first let me just add that most HT'ers are using them... notch filters are room equalization tools.Originally posted by danger boy
As for 2-ch, man you want to talk about an ancient debate To some tone controls are sacrilege, but 24 frequencies per channel of +/- 12 db, slide control equalization? Well that was just heresy. Then theres parametric vs. graphic(?) designs and
But to your questions:
- No, I dont own one, but in the past I have wanted one (dbx made a killer one years ago)
- True benefits are the ability to tame unruly rooms throughout the audible spectrum, and eek more out of a troublesome music source (old albums, old cassettes, even some old AAD CDs can benefit from hiss reduction and/ or bass boost)
- Yes, they color sound, but used properly they can improve the experience; problem was they were more often used to exaggerate bass or produce other unnatural effects and they got a bad rep.
They can be a lot of fun and do serious work at the same time.
EDIT: It just occurred to me that aside from any notch filter capability, I do have an EQ, and most of y'all do too. It's in one or more of your PC's music playback processors.
The MusicMatch Jukebox upgrade even claims to have an effective "pop'and click" eliminator for vinyl to CD xfers.... hmmmm, sounds like fun...
More later,
Tour...
Vox Copuli
