Fisher 500C faceplate
[Deleted User]
Hello,
Would anyone be able to send me a digital photograph of the glass section of a 500C faceplate? I need to be able to clearly see the dial markings and wording of the graphics used. I screwed up and washed off the decals on the inside of the glass. However, with a good digital photo there are companies who make decals.
Thanks much, Ken
Thanks much, Ken
I can certainly try to get you a clean photo of one of mine (either the good one or the not so good one). There were two flavors (at least) of 500C dial glass markings.
A scan would be even better, if someone has a disembodied one floating around... -
engtaz
...that's the "newer" dial scheme.
Hello,
Thanks, a digital photo would be much appreciated.
Ken -
Does this help at all, Mr. Ken?
This is my 'basket case' 500C, which was easier to get to than the nice one. Both have the same, newer-style dial glass markings.
The best bet, I'd guess, would be to remove the dial glass and scan it.
Sorry for the reflections! I can get you a better quality photo, with a ruler for scale, I'm sure... but not at night :-(
For comparison, here's an example of the other 500C "morph", which only had calibrations labeled every 4 MHz (4 MC, as they'd say back then!). I assume these were earlier production models.
http://www.quadesl.com/graphics/500c_pic.jpg -
Hello,
Thanks much, I'll ask my wife to take a look at those.
Take care, Ken -
My pleasure. I am sure I can get you something at least a bit better in quality.
I like the idea of a scan. Put some white paper behind it, scan it to a file that you can edit (color, smooth the lines, etc.) then get a decal made. Good luck Ken!
Nice Fisher Mark! Have you recapped anything in that beauty?Carl -
That's my basket case 500C! A winter project.
I picked up a 400, a 500B and a 500C recently reasonably inexpensively. All need work, but are believed to be restorable.
the 500B
the 400
I have a nice, restored 500C too, fortunately :-)
Real nice mark! Good luck on those projects. Post your experiences in the Forums. This stuff is fun.
I have a friend who has offered me his KM-60 (no cabinent) for $200, which I think is high. Additionally, I'm not sure of the condition. I've asked him to hook it up so I can hear it, and I'll give it a closer examination. Any tips for looking at one of these old "birds"?Carl -
My tales of Fisher restoration have been posted at audiokarma. The Fishers are fun and easy to refurbish, and well worth the effort. They are good looking and good sounding beasts.
$200 for a KM-60 in fine condition with good tubes sans case sounds OK to me in this day and age. See if they've got original tubes (especially the small-signal tubes), as Fisher used good ones (Telefunken and Mullard). If it's in working order, see (or ask) if the coupling caps have been changed. If that one has a selenium rectifier (e.g., in the bias/DC filament supply), ask/see if its been changed to a silicon rectifier/bridge. Listen for hum. After it has run for a few minutes, see if the P/S cap cans are cold, and see if the power transformer is anything but slightly warm. After longer run time, the P/S caps should stay cool, but may pick up heat from neighboring, hot items (e.g., the power tubes). Does the KM-60 have a tube rectifier? Some of the earlier Fisher gear did. The power transformer will likely get quite warm after it runs for a while, but that's OK.
Here's an early X-100 (7189 outputs) that I redid for a local fellow...
Just for fun and appropos of nothing...
(from the 1966 Lafayette catalog... the prices were dropping on the tube equipment; the solid state Fishers were also available)
I like reading the vintage audio ads. I bought my first stereo amp and speakers from a Lafayette Electronics store in 1967 with money from my paper route.
CarlCarl
