tube help...please
beardog03
beardog03 Posts: 5,550
edited October 2007 in Electronics
After selling my Mullards, I get this e-mail
Please help me respond quickly, as I do not know the answer
Thanks in advance..
Hi Robert,
The tubes arrived safely. I am new to tube rolling (still have my Naim
solid state chrome bumper). Are the Mullard 6sn7gt a direct
substitute for the domestic 6sn7. or are the Mullard 6sn7gt really a ecc33? I
don't want to stick the tubes in my amp and kill my amp.
Thanks,
Art
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Post edited by beardog03 on
  • janmike
    janmike Posts: 6,146
    edited October 2007
    Robert, why don't you direct him to the manufacturer and then NO mistakes are made. You may have to humble yourself a little, but things will be set right. Just my opinion.
    Michael ;)
    NORTH of 60°
  • beardog03
    edited October 2007
    Mullard ?
    or the Naim folks ?
    I`m not worried about looking stupid, as it`s kinda evident, and I told him I was a newbie myself... I just know that some folks here would know what to tell him..
    Russman...you out there ?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • Emlyn
    Emlyn Posts: 4,620
    edited October 2007
    I would agree that a call to the amp manufacturer by the new owner is in order so he can be sure, and to avoid a potential problem for yourself (I'm guessing the new owner was referring to a piece of Naim gear that is something other than the amp he's concerned about now). The Mullard 6SN7GT are not always a direct replacement for circuits that use 6SN7 tubes (maximum plate voltage dependent). Chances are if they're not compatible, he'll want to return them to you.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited October 2007
    What amp is Art running? The key is the voltage the circuit is putting on the plate. If it's 300v or less, no problems.
  • beardog03
    edited October 2007
    Thanks bro...I will e-mail and ask
    I don`t want to get a bad rep over a couple duckets
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • RuSsMaN
    edited October 2007
    It's probably going to be fine, most designs using a 6SN7 run it class A at 250v.
  • beardog03
    edited October 2007
    Thanks Russ, I e-mailed him what you said.
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
    F1nut Posts: 51,674
    edited October 2007
    I'd also like to add that the ECC33 is NOT a replacement for the 6SN7GT, the ECC32 is a variant, but not a direct replacement.
  • beardog03
    edited October 2007
    thanks Jesse, I also sent him what you sid..
    I believe I have given him every opp to be happy with his purchase...more than I usually get !
    Thanks for all your help guys...
    I think I`m going to go ahead and get my Popes now..:D
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
