tube help...please
beardog03
After selling my Mullards, I get this e-mail
Please help me respond quickly, as I do not know the answer
Thanks in advance..
Hi Robert,
The tubes arrived safely. I am new to tube rolling (still have my Naim
solid state chrome bumper). Are the Mullard 6sn7gt a direct
substitute for the domestic 6sn7. or are the Mullard 6sn7gt really a ecc33? I
don't want to stick the tubes in my amp and kill my amp.
Thanks,
Art
Thanks in advance..
Hi Robert,
Thanks,
Art
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool:
Robert, why don't you direct him to the manufacturer and then NO mistakes are made. You may have to humble yourself a little, but things will be set right. Just my opinion.Michael
NORTH of 60° -
Mullard ?
or the Naim folks ?
I`m not worried about looking stupid, as it`s kinda evident, and I told him I was a newbie myself... I just know that some folks here would know what to tell him..
Russman...you out there ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
I would agree that a call to the amp manufacturer by the new owner is in order so he can be sure, and to avoid a potential problem for yourself (I'm guessing the new owner was referring to a piece of Naim gear that is something other than the amp he's concerned about now). The Mullard 6SN7GT are not always a direct replacement for circuits that use 6SN7 tubes (maximum plate voltage dependent). Chances are if they're not compatible, he'll want to return them to you.
What amp is Art running? The key is the voltage the circuit is putting on the plate. If it's 300v or less, no problems.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Thanks bro...I will e-mail and ask
I don`t want to get a bad rep over a couple ducketsCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
It's probably going to be fine, most designs using a 6SN7 run it class A at 250v.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Thanks Russ, I e-mailed him what you said.Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
I'd also like to add that the ECC33 is NOT a replacement for the 6SN7GT, the ECC32 is a variant, but not a direct replacement. -
thanks Jesse, I also sent him what you sid..
I believe I have given him every opp to be happy with his purchase...more than I usually get !
Thanks for all your help guys...
I think I`m going to go ahead and get my Popes now..:DCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool:
