Best Tweak yet
PolkThug
Rio
Place the CD and DVD etc. on top of RIO-5 II, and press the red button. This will run the electric fan for 14 seconds, which irradiate the surface with natural negative ion on to the disc. RIO-5 II not only releases negative ion, it also emit infrared rays which works as a surface-active agent. This improves transmissivity of the laser beam inside the CD player, which leads to improved sound and picture quality. By using the RIO-5 II, it improves S/N ratio and dynamic range. All instrument and vocals become vivid and sounds fresh. On the picture, it gives depth and excellent color contrast.
Post edited by PolkThug on
Have you actually experienced this, or did you get caught up in the ionic marketing force irradiating from the website?DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Nice; all that for just a little below $600. Imagine how you could improve your system if you call for the teleportation tweak WHILE you are bombarding your CD with negative ions...._________________________________________________
But will it make my wanker bigger?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
You do realize that CDs are digital binary code right?
CDs are not records... they contain a large amount of data parity, enough where the player can reconstruct bit-perfect data even with large scratches, when the player is designed correctly.
I get caught up in a lot of audiophile stuff... but this CD treatment crap is about as useful as Brilliant Pebbles and Clever Little Clocks, except you can use the clock to tell the time and the pebbles make an interesting ornament. -
No, but apparently it will spray your wanker with negative ions...sounds kinky, I'll take it.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Russman - it won't make your wanker longer, but it will add clarity and definition
DKG999
It's not the size of your boat, after all, but the motion of negatively charged ions, which oddly enough, the ocean is full of. Hmm...
Pass on the ionic wanker spray, but I could use some surface agent IR rays (I need a little color).
....and what kills me is that someone at that company had to actually talk that unit up to "sell" it.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
Worse than that, some "engineer" designed this POS. I wonder if the parts list included fairy dust?
However, you will then need to find a positively ion charged wanker insertion device.........do not ask how I know this......but if the postively charged wanker insertion device holds the negatively charged wanker for more than four hours you should call a doctor........
RT1
