Very dumb question: which terminal do I use for my Rti8
bronxkid
bronxkid Posts: 21
I felt embarrassed asking this in the speaker/highly technical forum, but I'm connecting my RTi8 and there are two sets of terminals. I'm not bi-amping so which one do I use? Also, the terminals don't appear to be labeled +/-. Thanks.
Post edited by bronxkid on
    F1nut Posts: 51,756
    edited October 2007
    As long as the binding post plates are used, it doesn't matter if you connect the speaker cables to the top or bottom posts. Red is positive, black is negative.
  • bronxkid
    bronxkid Posts: 21
    edited October 2007
    Thanks. I know the red/black is probably standard but I just wanted to be sure. :)
  • steveinaz
    steveinaz Posts: 19,545
    edited October 2007
    Just so you know for future reference, the bottom posts are for your woofer(s), upper posts for midrange/tweeters. As F1 said, make sure the brass shorting strap is attached if you're not bi-wiring/bi-amping; that way the signal is being applied to all drivers.
