Digital Coax or Fiber Optic cable?
    edited October 2007
    coax is digital to digital
    optical is dig to light - light to dig
    2 extra conversions
    K.I.S.S.
    In my system Coax was definietly better.
    I bought coax on a whim thinking there would be no difference, but I prefer coax over optical.
    Ben
    edited October 2007
    I think Toslink would be best suited for an already warm system, such as a tube system. Coax or XLR for solid state, generally speaking.
    edited October 2007
    According to several Monster Cable product reps, Digital Coax has more bandwidth than Fiber Optic. With my experiences, in being a Supervisor and Home Theater Installer for Circuit City, and with my own setups, I've found that the cables, provided they are constructed of half-way decent materials (Non-chinsey connectors, Nitrogen Injected Dialectric, and a good amount of shielding, or fiber optic lenses that are polished and decent sized), it comes down to the devices being connected. In theory, I'd say Fiber Optic works better for cheaper components, because you are much less likely to get a solid 75 ohm connector on a CyberLink 40 dollar dvd player as you are on a Denon DVD player, which would be the biggest factor of data loss. Its easier to maintain a 75 ohm signal at the circuit board level, where you'd be converting the data into light pulses, than it would be in transfering that signal to a cheap RCA-type jack.
    In my opinion, I'd say the best way to go would be to have components that use BNC connectors for a Digital Coax connection.
    Now, what about the differences between Fiber, Digital Coax, and HDMI or Firewire?
    edited October 2007
    More bandwidth than Fiber Optic?
    Michael ;)
    NORTH of 60°
    edited October 2007
    janmike wrote: »
    Depends on the material used (glass or plastic fiber), the length of the cable, and how well polished/well fitting the terminations are. A good glass fiber cable will easily pass 96kHz bandwidth. More than adequate.
    Here's an example of a good Toslink cable (quartz-glass):
    http://www.impactacoustics.com/product.asp?cat%5Fid=901&sku=40231
    edited October 2007
    There is no difference in cables you are likely to hear.
    edited October 2007
    Did you try my test mentioned earlier in this thread concerning bass-heavy material and Toslink? Give it a try....tell me what you think.
    edited October 2007
    ka7niq wrote: »
    Coming from the "know it all and everyone", must be true.
    SOPA
    edited October 2007
    steveinaz wrote: »
    This is the same optical cable I use in my computer rig. I don't have the ability to compare 75 ohm coax to optical, but this is a very sturdy, glass optical that won't break the bank.
    I believe www.cablestogo.com has them slightly cheaper.
    I can hear very distinct differences in cables, both speaker and interconnects on my main rig. The only way to know for sure is to try it yourself.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | BlueSound Node3 - Tubes add soul!
    edited October 2007
    Thanks for the linky.
    engtaz
    engtaz
    edited October 2007
    engtaz wrote: »
    engtaz
    No problem, looks like they are the same price, perhaps it was the shipping that was cheaper :confused: . Anywhoo, I bought my Impact Acoustics cable from Cables to Go and was very satisfied with the price and service I recieved.
    edited October 2007
    I remember now, I linked to Cables to Go through Amazon and since the price was more than $25 I got free shipping at the time (2 years ago or so)
    edited October 2007
    ben62670 wrote: »
    2 extra conversions
    K.I.S.S.
    You're grouping transmission methods (electricity, light) and an encoding method (digital) together; that doesn't make sense.
    It's all digital; coax just conveys the data with electricity while fiber conveys the data with light.
    If you replace "dig" with "electricity" then what you say makes more sense. However it isn't necessarily reasonable to assume that a conversion from electrical impulses to light impulses and back again will introduce any signal degradation.
    MM
    edited October 2007
    mmcculloch wrote: »
    MM
    Yes you got me. But why do 2 extra conversions (to optical) when you can go straight electrical to electrical impulses. I have tried both, and coax won hands down, and I was a 1 is a 1, and a 0 is a 0 kinda guy.
    Ben
    edited October 2007
    jfeinman wrote: »
    When we're talking about carrying digital audio under the S/PDIF protocol, they both have adequate bandwidth. Even if one has more available bandwidth than the other, it won't make any difference.
    MM
    edited October 2007
    Digital coaxial, all day, every day.
    edited October 2007
    They are both equally the same optical and Coaxial digital, I have done a side by side test and its all the same.
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
    edited October 2007
    Coax is a solid connection, fiber can be a bit flakey and loose. Anyone who says there is and audible difference is fooling themselves, a common phenomenon.
    edited October 2007
    louthewiz wrote: »
    Absolutely on some players. On my Sony Coax hands down.
    Ben
    edited October 2007
    mjhughes wrote: »
    Fiber is no more "flakey and loose" than copper but I prefer a copper connection in all things audio. Audibly, I agree 100%, as I've heard nothing different.
Welcome!
Welcome!
