Is this a bad ting
beardog03
I`m suffering from lack of rack, sothe new amp is sitting right were the old one was....on top of the pb10..
This isn`t a good idea , is it ?!!
vibrations...magnet....
okay flame away....:rolleyes:
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool:
Post edited by beardog03 on
My guess is that the mass loading of the PB10 cabinet with the amp is tightening up your bass
This might be a tweak that you want to apply for a patent for and charge $250 or so for audiophile consultation
A couple of concrete blocks and a couple of short pieces of 1x8 will fix that problem pronto!DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
If you absolutely must keep that there for let's say a month or so, go to Mapleshade and get these. They will keep you relatively safe and in business for a while and after you move the item to a more appropriate home, you can reuse the Isoblocks.
last time I contacted the patent office they said there was a patent on stupid already, and to quit calling them...!!!
and to not stalk the girl that answers the phone anymore either...!!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
thanks HP !
have a pair of those that Mark gave me at PF a few years ago...cool !Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
thanks HP !
You've been talking to Harry Pearson from TAS again or did you forget the evening dose?:D -
Ha thats greatHT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
There was another forum member that had his receiver propped crookedly ontop of a bookshelf speaker.
This isn't nearly as bush-league, but I wouldn't leave it as your long-term solution. But, hell, if it looks okay to you, it's not hurting anything at all.
I would make sure you don't ruin the finish of the sub with the amp sitting on it. But, I'm sure you have some kind of protection inbetween them.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Here's my stereo cabinet that I used: http://www.ikea.com/us/en/catalog/products/00045560
Nice and Cheap!
Place finger on piece of gear, feel vibration???? Cheap is as cheap, well, IS!:D
My gear is not anything like the speaker lean from the past !!
Sorry bout the abbrev HEARINGIMPARED !!.....again :rolleyes:
The sub already had some marks on the top, but ...it is what it is
I put the iso feet under it as not to mark it up any more than it already had..
it`s just temparary, as I spent all my $$ on the new amp..!!
I just didn`t want to mess up the new amp , for what ever reason...
dat`s awl..Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
That is nuts Lasareath do you have hearing aids yeat.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
he said what, he couldn't hear you
What I cant hear you. and I am your nieghbor HAHAHT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
It's such a bad bad thing that you should have carried it out to my trucks front seat...it would have been much more comfortable
The first rule of Fight Club is you don't talk about Fight Club -
Come on Joe, When I crank my system the whole house vibrates, You can go half way down my block and hear Alison Krauss singing. Do you think it really matters if my $80 cabinet is vibrating?
Even if I had a 4" thick slab of marble what does it matter if my amps, CD player & Reciever are vibrating?
Sal
Isolation will kill the resounance which will improve the sound of any piece of audio gear.
My floor problem has been resolved. I just pushed the brass and decoupling points down through the plywood plank into the concrete below. Did you really think I was going to live with that the way it was. -
It might make your Caps leak
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
my caps been leaking for years ,bro....Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool:
