good universal remote?
AdamRagland
just bought a denon 3802 on ebay for 150 but it doesnt have the remote. anyone have any advice or experience with any other universal remotes? my concern is that i wont be able to access the diffrent options and settings for the 3802 unless i have that remote. am i wrong?
Post edited by AdamRagland on
Harmony, if you don't want to spend over 500$
I loved my Harmony when I had it. Now have the 720 and am just as satisfied with this one.
Harmony 550 under $80.
engtazengtaz
I personally have a Universal Remote RF20. It is a great remote, easy to program and you can get it with the radio frequency converter box so that you can control components through walls, cabinets, etc. It is less than $100, sometimes you can get it for about $65 on amazon. Here is the link,
http://www.universalremote.com/product_detail.php?model=102
After using count less remotes about to around $600, this is by far the easeset to use and program, its learning mode is awesome.
Josh -
The Harmony 550 and Xbox360 remotes are also excellent but (1) require AAA batteries that need replacing because of the backlit LCD screen rather than a rechargeable lithium-ion battery; (2) have only 4 soft custom label buttons compared to 6 for the 720, or eight for the 880; (3) have a monochrome LCD screen, not color, and it can be hard to read on the 550 (bright blue with black text).
AAA batteries lasted more than 2 years in my 520 (older rev of 550), so not a big deal.
Never had problems reading black on blue on 520, but it's really person dependent, I guess.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Harmony
I buy rechargeable AAA's.
engtazengtaz
Logitech Harmony NOTHING NOTHING MORE NOTHING LESS BECAUSE ITS THE BEST!!!!! any modelHT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
I switched from the TSU3000 to the harmony 880. Never been happier. It's easy to use and real easy to program. I got mine new on e-bay for $130.00Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
Harmony 1000. Love it.Michael
NORTH of 60° -
I really like my MX500 - $75 bucks on eBay Chris
I should mention WHY I like the MX500 - cheap if you're on a budget, great feel and backlighting, my wife picked it up and started using it with no questions - high WAF - Chris
Ya, I think this is the only product that I wish had a low WAF.Now, with the new remote, it's easy for her to use my gear:eek: I have mixed emotions about that. I'm glad she is enjoying it, but I worry.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880 -
I got the Harmony 676 for 49 bucks on amazon. It is the best remote I have ever owned. Would have paid twice that had I known how easy they are and how great they work.
ShawnShawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
