good universal remote?
AdamRagland
AdamRagland Posts: 521
edited October 2007 in Electronics
just bought a denon 3802 on ebay for 150 but it doesnt have the remote. anyone have any advice or experience with any other universal remotes? my concern is that i wont be able to access the diffrent options and settings for the 3802 unless i have that remote. am i wrong?
Post edited by AdamRagland on
  • Willow
    Willow Posts: 11,229
    edited October 2007
    Harmony, if you don't want to spend over 500$
  • dane_peterson
    dane_peterson Posts: 1,903
    edited October 2007
    I loved my Harmony when I had it. Now have the 720 and am just as satisfied with this one.
  • engtaz
    engtaz Posts: 7,669
    edited October 2007
    Harmony 550 under $80.
    engtaz
    engtaz
  • jmuma2k
    jmuma2k Posts: 13
    edited October 2007
    I personally have a Universal Remote RF20. It is a great remote, easy to program and you can get it with the radio frequency converter box so that you can control components through walls, cabinets, etc. It is less than $100, sometimes you can get it for about $65 on amazon. Here is the link,
    http://www.universalremote.com/product_detail.php?model=102
    After using count less remotes about to around $600, this is by far the easeset to use and program, its learning mode is awesome.
    Josh
  • ViperZ
    ViperZ Posts: 2,046
    edited October 2007
    Kex wrote: »
    The Harmony 550 and Xbox360 remotes are also excellent but (1) require AAA batteries that need replacing because of the backlit LCD screen rather than a rechargeable lithium-ion battery; (2) have only 4 soft custom label buttons compared to 6 for the 720, or eight for the 880; (3) have a monochrome LCD screen, not color, and it can be hard to read on the 550 (bright blue with black text).
    AAA batteries lasted more than 2 years in my 520 (older rev of 550), so not a big deal.
    Never had problems reading black on blue on 520, but it's really person dependent, I guess.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • woofiepaws
    woofiepaws Posts: 222
    edited October 2007
  • engtaz
    engtaz Posts: 7,669
    edited October 2007
    I buy rechargeable AAA's.
    engtaz
    engtaz
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited October 2007
    Logitech Harmony NOTHING NOTHING MORE NOTHING LESS BECAUSE ITS THE BEST!!!!! any model
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • MSALLA
    MSALLA Posts: 1,602
    edited October 2007
    I switched from the TSU3000 to the harmony 880. Never been happier. It's easy to use and real easy to program. I got mine new on e-bay for $130.00
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • janmike
    janmike Posts: 6,146
    edited October 2007
    Harmony 1000. Love it.
    Michael ;)
    NORTH of 60°
  • wz2p7j
    wz2p7j Posts: 840
    edited October 2007
    I really like my MX500 - $75 bucks on eBay Chris
  • wz2p7j
    wz2p7j Posts: 840
    edited October 2007
    I should mention WHY I like the MX500 - cheap if you're on a budget, great feel and backlighting, my wife picked it up and started using it with no questions - high WAF - Chris
  • MSALLA
    MSALLA Posts: 1,602
    edited October 2007
    Ya, I think this is the only product that I wish had a low WAF.Now, with the new remote, it's easy for her to use my gear:eek: I have mixed emotions about that. I'm glad she is enjoying it, but I worry.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • shawn474
    shawn474 Posts: 3,052
    edited October 2007
    I got the Harmony 676 for 49 bucks on amazon. It is the best remote I have ever owned. Would have paid twice that had I known how easy they are and how great they work.
    Shawn
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
