can't tell my left from right
RM65
This has to be a common question. Just bought a used pair of RT 35s and an old Harmon Kardon HK 450. Sounds great .. but am curious as to how to distinguish the left from right speaker, or if there is a difference with these models.
Post edited by RM65 on
The speakers are the same left or right.
Enjoy and welcome to the forum! -
Thanks very much for the reply and info.
They looked the same to me, so I figured they are interchangeable. -
There is a way to verify:
1. Sit at your listening position
2. Make sure you're head to pointed straight at the soundstage
3. Lift and fully extend your right arm
4. Fully extend your right index finger
5. Move your right arm approximately 45 degrees to the right
6. You are now pointing at your RIGHT speaker
Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
LOL! Steve you are crazy!:D
RM65 welcome to CP!:)Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
WAAAAAAAAAAAAAAAAAAAAAAAAA
RM65, welcome. You're not the first, nor you will be the last to ask that question. Enjoy!Political Correctness'.........defined
