can't tell my left from right
RM65
RM65 Posts: 2
This has to be a common question. Just bought a used pair of RT 35s and an old Harmon Kardon HK 450. Sounds great .. but am curious as to how to distinguish the left from right speaker, or if there is a difference with these models.
Post edited by RM65 on
  • VSchneider
    VSchneider Posts: 443
    edited October 2007
    The speakers are the same left or right.
    Enjoy and welcome to the forum!
  • RM65
    RM65 Posts: 2
    edited October 2007
    Thanks very much for the reply and info.
    They looked the same to me, so I figured they are interchangeable.
  • steveinaz
    steveinaz Posts: 19,545
    edited October 2007
    There is a way to verify:
    1. Sit at your listening position
    2. Make sure you're head to pointed straight at the soundstage
    3. Lift and fully extend your right arm
    4. Fully extend your right index finger
    5. Move your right arm approximately 45 degrees to the right
    6. You are now pointing at your RIGHT speaker
    :D
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2007
    LOL! Steve you are crazy!:D
    RM65 welcome to CP!:)
    F1nut Posts: 51,798
    edited October 2007
    steveinaz wrote: »
    :D
    WAAAAAAAAAAAAAAAAAAAAAAAAA
    RM65, welcome. You're not the first, nor you will be the last to ask that question. Enjoy!
