Adding new subs and third amp (need wiring advise)
rz22g
rz22g Posts: 70
edited October 2007 in Car Audio & Electronics
I have two new SR 124DVC's and a new C500.1 on the way to me. I already have one C500.1 and a C400.4. My current wiring is as follows.
4 Guage wire from battery to fuse holder 6" from battery with a 100 amp fuse, continuing back to a dual fuse box. Fuse box has 2 60 amp fuses, one feeds out to the C500.1 and the other to the C400.4
Im going to get a new fuse box that will output to at least 3 amps to replace the current box.
So my question is..
What size wire do I need to get to replace the 4 guage wire from the battery to the fuse box... if any?
Post edited by rz22g on
  • MacLeod
    MacLeod Posts: 14,358
    edited October 2007
    1/0 gauge.
  • rz22g
    rz22g Posts: 70
    edited October 2007
    MacLeod wrote: »
    1/0 gauge.
    Thanks. What are you thoughts on distribution? If Im fused 6" from the battery with the appropriate sized fuse, is a fused distribution block really necessary or can I just go with a distribution block?
  • exalted512
    exalted512 Posts: 10,734
    edited October 2007
    each amp needs to be individually fused.
    -Cody
  • MacLeod
    edited October 2007
    Unless the amps dont have fuses in them internally, you dont need to fuse each one at the distribution block.
    Nothing wrong with doing it that way as its an extra layer of protection, but the amps internal fuses will work just fine.
  • rz22g
    rz22g Posts: 70
    edited October 2007
    MacLeod wrote: »
    Well I have already orderd a fused block. According to Polks manuals for the amps I have, each one is 60 amp total, so I ordered three 60 amp fuses for the block.
    Now my current fuse at the battery is 100 amp. Unless Im looking at this wrong, it needs to be 180 but I think 150 is my only choice. In addition its an AGU fuse holder and I cannot locate any fuse larger than 80amp. How the fuse in there is 100amp I dont know but it is.
    Am I going to need to change my fuse holder or will the 100 amp fuse hold?
  • Installer4life
    Installer4life Posts: 256
    edited October 2007
    rz22g wrote: »
    You will need to upgrade your fuse holder and fuse to the ANL type or get a circuit breaker. I seriously doubt you will draw that kinda of power under normal listening conditions but you can go with a 200 amp fuse if you like. I don't know if they make a 180 amp. Besides the AGU fuse holder is not available in a 1/0 size.
  • exalted512
    edited October 2007
    ^^what he said.
    -Cody
  • rz22g
    rz22g Posts: 70
    edited October 2007
    Thanks for the info. I went ahead and ordered an ANL fuse holder and a 150 amp fuse.
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited October 2007
    You'll pull ~120 @ full power, and you'll need a minimum conductor size of 4 awg, although that'll leave you with as much as a 1 volt line drop... I'd go with 2 awg.
    The Artist formerly known as PoweredByDodge
